help!!! crank but no start!
i cheked all my other fuses
i got new spark plugs and wires
new battery
looks like im getting fuel.
and changed the ecu as well..
but still no turn over.
urgh!!!
new battery
urgh!!!
pull the carpet back and on the passager floor board the will be a plate remove it.
unfer the plate the ecu will have a small little round window turn the key to acc. and count the flashes.
count them write them down, then come back. a code will look like this for example. they consit of long flashes and short flashes
examples
long long long short short=32
long= 10
long short short short short=14
short=1
understand?
examples
long= 10
short=1
understand?
ok..so i chekd my fuel presure..
took off the fuel lines
and my gas jst over flows,doesnt shoot up..
im guessin loss of pressure.??
..and im guessin means i need a fuel pump??
Same thing happened to me on my 93 civic, Its your alternator trust me take it out and check if its working, I had the same problem i messed with my timing bought a new distributor, a new fuel pump, changed the interior and exterior fuse box, i even changed my ECU............and after time and money spent,,,,,,it was my dam alternator@! make sure you get a new one not those rebuilt ones cus they suck.
hybridmath
30
Jul 20, 2008 03:38 PM
