integra wont start in the morning
Old Mar 31, 2009 | 10:04 AM
soto2635's Avatar
Default integra wont start in the morning
i go to work at 330 am everyday, yesterday i got in the car and it would start i got interior lights and i could hear the fuel pump, but it wont even crank over so i jumped it then it turned on with no problem. same thing today but when i went to jump it, it didnt do anything, when i got home around noon i put the key in it it turned over with no problem wtf could it be??
Old Mar 31, 2009 | 08:31 PM
teggy199018's Avatar
Default Re: integra wont start in the morning
ur battiery cables or its not grounded to the tranny rite
Old Mar 31, 2009 | 08:51 PM
jdm inc's Avatar
how cold is it out
i had this problem when it was really cold out and it ended up being the battery not having enough cold cranking amps and when it got hotter out it started just fine.
Old Mar 31, 2009 | 10:20 PM
my_hidden_romance's Avatar
sounds like the cca on the battery
Old Apr 1, 2009 | 09:44 AM
5litereater's Avatar
Sounds about right. Worth checking out your grounds too...
Old Apr 1, 2009 | 09:47 AM
connor53's Avatar
possibly a "dead" spot in the starter as well. I've seen that before.
totsie7944's Avatar
I'd toss ina new battery for starters...when you say you "jumped it" did you hook it up to another car or did you let it roll and pop the clutch? I only ask because people use the term in both ways, and if its the second one, you might need a new starter...
Old Apr 1, 2009 | 04:15 PM
soto2635's Avatar
no it a auto i used my other car to jump start it
Old Apr 1, 2009 | 04:19 PM
soto2635's Avatar
Originally Posted by jdm inc
how cold is it out
when i got to work it about 50-60 degrees this is at 330am, but wont it start even if i hooked it up to my other car
Old Apr 1, 2009 | 04:28 PM
soto2635's Avatar
what this cca?, never mind...
Old Apr 1, 2009 | 05:50 PM
XxNampsterxX's Avatar
It could also be the main relay
Old Apr 1, 2009 | 11:24 PM
50-60 is nothing for cca then... its something else... try your grounds... i was thinking u were talking 20-30 .. since thats usually the problem here in south dakota... its 10 or 12 degrees cars hate starting... thats why we have to plug in battery chargers and block heaters
Old Apr 2, 2009 | 05:15 AM
AWJDMDA9's Avatar
id check all the grounds and rota button
Old Apr 2, 2009 | 05:20 AM
acin92's Avatar
New User
I have a 92 integra and mine does that at times as well. What i do is when it acts up i turn the ignition switch to on and wiggle my battery terminals until i hear the door chimmer then it will start. But if thats ur problem i would install new battery cables.
Old Apr 2, 2009 | 05:31 PM
soto2635's Avatar
problem solved it was the battery the cells were dryed out
Old Apr 3, 2009 | 08:14 AM
soto2635's Avatar
never mind it did it again today around 7am, it was about 60-70 degrees out this morning i left and when i came back around 9am i put the key in and it started rite up w/ no problems, im about to lose my mind, i switched the batteries out with my other car which is an otima red top so i have to wait till nite time to see it it turns on. its so frustrating the same thing i had power on the inside and the radio and all that worked but when i turned the key nothing all i hear is the damn fuel pump
Old Apr 3, 2009 | 08:23 AM
ekmushi_mushi's Avatar
yep mine does the damn same thing...after like 20-30 try of pumping the clutch and turn the key to ignition is finally start..but if u fine the answer to this symptom message me and let me know bro..i have an LS in my hatch..why this is pretty commen problem for integra motor
lol..i turn the key to ignition then pump the clutch and nothing happen, but then when i release the key to on the radio and everyindicator in the guage work and radio and everything work but motor doesnt turn on...
Old Apr 3, 2009 | 10:18 AM
acin92's Avatar
New User
sounds like u need a starter but what i would do is check the wires on the starter for good connection first then go from there but it sounds like starter because u say u here the fuel pump so u got fuel and if it starts sometimes then obviously u got fire.
Old Apr 3, 2009 | 10:35 AM
90SiReX's Avatar
my 91 da used to do the same thing. i used to have leave the key turned to II and just pump the clutch till it cranked, x2 for bad starter
Old Apr 3, 2009 | 12:08 PM
soto2635's Avatar
the car's auto
Old Apr 3, 2009 | 03:16 PM
HondaTom87's Avatar
Bad starter... has to be... or the only other thing that I could possibly think is an alarm that is acting up.. That happened to me once before but I would check out the starter connections first. If they seem to be fine then pull the starter and hook it up to the battery see if it pops out and rotates.
Old Apr 3, 2009 | 05:33 PM
soto2635's Avatar
yea iam check the starter out, b/c i dont have an alarm
Old Apr 4, 2009 | 07:14 AM
bada9's Avatar
ekmushi mushi...check your clutch pedal position sensor, my ls 92 teg did the same thing and if i would push on the clutch pedal super hard it would crank and start right up for me
Old Apr 7, 2009 | 06:51 PM
soto2635's Avatar
so far its still doing it, i plan to replace all the grounds what size guage should i use??
Old Apr 8, 2009 | 07:16 PM
the car's auto
WhiteNeko
Jul 30, 2012 04:35 PM
FLA$HY_5SiX2
Nov 8, 2011 02:57 AM
midoriboy
Honda Motorcycles
Jun 11, 2010 11:44 AM
dvlsfan30
Oct 21, 2008 05:09 AM
cow1787
Dec 29, 2007 08:27 PM
