Sony MEX-DV2000 in '04 Honda Accord EX V6 Navi
Here is the wiring diagram I made to integrate the Sony MEX-DV2000 into the Honda Accord EX V6 navi ('04 only).
This weekend I did a lot with the car. I dremeled the hell out of the center console above the radio to accept a 5.25" speaker above the navi sub-display. It is in the same location as the TL's 3.5" speaker. I also ran an RCA cable from the center dash storage space (where the MEX-DV2000 is going to go) to under the passenger seat (where the center channel amp will go). I also ran a remote in, power and ground cables from my sub amp underneath my driver's seat to under the front passenger seat for my center channel amp. I finally ran speaker wire from under my front passenger seat to the center storage dash area. and wired up the center channel speaker.
I get the Sony headunit on Tuesday, so I will be messing with it that night. Now, I just need to figure out which wires go where from the Sony headunit to the Accord's wires. The speaker wires I got.
http://www.xplodsony.com/files/manua...all_Manual.pdf
Looking at the above installation manual, here is what I know (from the MEX-DV2000):
1.) Black - Ground
2.) Blue - Antenna Remote
3.) White/Blue Color - To Amplifier Remote In
4.) Lt. Blue - Attenuator (interface cable of car telephone)
5.) Orange/White - Illumination (+)
6.) Red - +12V Accessory (switched)
7.) Yellow - +12V (hot at all times)
8.) Lt. Green - Parking Brake (ground)
Since the Accord wiring diagrams could be found here:
http://www.driveaccord.net/forums/sh...ad.php?t=29160
I think what I have is right.
#1 above will go to the black ground wire, pin A20 from the Accord's audio unit.
#2 above will go to the yellow/green antenna power wire, pin A1 from the Accord's audio unit.
#3 above will go to the blue amplifier remote in on the aftermarket amp I have
#4 above will go to the interface cable of a car telephone, which I don't have. Could this be hooked up to the OEM navigation voice somehow?
#5 above will go to the red/black dim control wire, pin A9.
#6 above will go to the yellow/red switched ignition wire, pin A2.
#7 above will go to the white green battery input (hot at all times), pin A10.
#8 above will go to the parking brake wire, but could this wire be hooked up to ground?
1.) Black - Ground
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Are you trying to keep the stock radio while doing this? They do make a harness for this car.
ajcrouch2016
Jul 1, 2016 12:30 PM
GsR HtCh
Aug 19, 2002 05:57 PM
