Help! Diy headgasket!?
Old Mar 31, 2009 | 09:04 AM
tony7626's Avatar
Default Help! Diy headgasket!?
i overheated, all my coolant came out, and i had to drive and stop and drive to get home. now i have white smoke coming out of my exhaust. Just got my new OEM headgasket in today and i am going to be doing it myself. Its a b16a but i am worried about my timing after i put it back together. any tips? does anybody have a write up for a b16? thanks
Old Mar 31, 2009 | 09:45 AM
schock3's Avatar
Default Re: Help! Diy headgasket!?
google it
Old Mar 31, 2009 | 10:08 AM
tony7626's Avatar
Originally Posted by schock3
google it
i have been looking everywhere. half my sensors are already unplugged. i found a d-series write up. but i heard on a b-series you have to pull your cams. i really need to get this car back up and running its my only form of transportation. i have to take my moms car and its getting annoying. i miss my vtec already =[.
Old Mar 31, 2009 | 10:13 AM
sleepingciv's Avatar
go here and make an account takes like 2 min to make then download the manual
http://www.hondahookup.com/manuals/
Old Mar 31, 2009 | 10:57 AM
aaronhume's Avatar
x2
and you will reset all of your timing anyway when you replace the head gasket. read the shop manual and you will learn a lot. and make sure you have good enough tools for the job when you change the gasket. you will need a good 1/2" drive ratchet/breaker bar with a 14mm socket (i think 6 point) for the head bolts if you want to make the job fast.
Old Mar 31, 2009 | 11:27 AM
tony7626's Avatar
Originally Posted by aaronhume
x2
that website is down...do you have a link?
Old Mar 31, 2009 | 11:30 AM
sde780's Avatar
Plan at least double the time you expect to use, something will go wrong as always when working on cars.
Old Mar 31, 2009 | 11:32 AM
the site is up and running i was just there did you click the link i posted?
Old Mar 31, 2009 | 11:37 AM
ahh i see there bandwith crap lol
go here
http://carservicemanuals.blogspot.co...ch/label/Honda
Old Mar 31, 2009 | 11:39 AM
tony7626's Avatar
yes, it said manuals are not available because of bandwith issues. i tried again and it worked this time. should i use the manual for a 2000 civic Si?
Old Mar 31, 2009 | 11:41 AM
yep
Old Mar 31, 2009 | 12:13 PM
4drEF's Avatar
Keyboard Humorist
You may want to consider getting a new thermostat while you are at it.
It's common for the thermostat to get damaged internally after overheating.
Old Mar 31, 2009 | 12:42 PM
aaronhume's Avatar
if you can find it online, its a vtec supplement manual for 90 crx with b16a. that one will be extremely close to your car, and therefore is the most helpful.
edit: it may be at this site, but my internet is slower than snails so i cant confirm right now
http://pdftown.com/Pdf-eBook/Honda.html
fire_fighter97
Oct 19, 2010 11:04 PM
jrap1243
Nov 3, 2007 02:19 PM
Strikerrr
Jul 25, 2005 05:44 PM
Kyles ej1
Mar 6, 2005 09:45 AM
95dc2
Dec 9, 2003 11:55 AM
