do i need a resistor box???
Old Mar 31, 2009 | 07:21 AM
jdmdikk's Avatar
Default do i need a resistor box???
i just purchased a set or rc 1000cc injectors and i was told from the guy that i purchased from ,that i would need a resistor box since its over 550cc..is this true????
**i have a resistor box already,,but i dont want to burn my ecu
Old Mar 31, 2009 | 07:38 AM
VtecSyndrome's Avatar
Default Re: do i need a resistor box???
Yes it's true, injectors that large to require resistor boxes. I'm about 99% sure you can use any Honda one and be just fine
Old Mar 31, 2009 | 07:49 AM
ekb16's Avatar
should of bought the new Bosch 1000cc injectors..no need for resistor box
jdmdikk's Avatar
yea men i have a integra 1 ,,i already have a site that shows me how to wire it up,,i just need a definet answer dats all..
Old Mar 31, 2009 | 09:45 AM
joelmatt89's Avatar
the way i understand it is if you have an obdI ecu and your injectors are running from 3-4 ohms of resistance you need a resisitor box. When it comes to the box anything that is providing you with 10 ohms of resistance will work, if you can't find one you could just go to radioshack and get four inline 10 ohm resistors. So if you want to make sure just test the resistance between the two prongs on your injectors the new ones will be 3-4 and if the old ones are 12-14 you need a resistor box. I know that is how it works when your using injectors that are different obd therefore i would think it would be the same for high performance injectors
Old Mar 31, 2009 | 10:35 AM
GetawayInMoscow's Avatar
FWIW RC makes up to 750cc injectors that do not need a resistor box
Old Mar 31, 2009 | 11:25 AM
Well I guess the debate has begun again..
To straight answer your question: just use an ohm meter on your injectors and if they are 2-4 then you need a resistor box to prevent your ECU from frying, period
Old Mar 31, 2009 | 11:46 AM
boostedcivicsir's Avatar
Mr. Badwrench
done. end of thread.
thats it in a nut shell.
Old Mar 31, 2009 | 12:03 PM
joelmatt89's Avatar
I think thread may have actually been done when i said the exact same thing two posts earlier.
Old Apr 1, 2009 | 06:13 AM
jdmdikk's Avatar
thanx guys..i quess ill check the ohms with a meter and see what my car says now and the rc injectors..
on-site ej1
Dec 16, 2008 10:53 AM
food
Dec 29, 2007 06:49 PM
Mr_Bojangles
Jun 18, 2004 09:07 AM
redboost10
Oct 23, 2003 03:35 PM
