Rattle tech!/ Cluster swap
Old Mar 31, 2009 | 06:33 AM
Dark_Teg's Avatar
Default Rattle tech!/ Cluster swap
Finaly got to drive the CRX yesterday and it is a beast!! Now that bad part....With the Hasport mounts the engine rattles the hell out of the car. The dash and sunroof are driving me insane!!!
I am going to remove the dash, install some dynamat and rubber washers to hopefully cure the dash rattles. While the dash is out I figured I would replace the cluster since the speedometer squeeks the entire time you are driving(squeek,squeek,squeek)
I am not sure what to do about the vibrating sunroof. Suggestions??
What cluster is the "easiest" swap with the highest redline? I hate wiring!
Thanks,
Old Mar 31, 2009 | 06:35 AM
95gainfla's Avatar
Default Re: Rattle tech!/ Cluster swap
probably either 99-00 si/94-01 gsr cluster. those seem to be pretty damn easy(especially with the whole dash out of the way, and they look pretty sick too.
as for sunroof, maybe delete it? unless you want it, then i suggest getting some subs so that when everything is rattling, you can just think its all from the subs and not the engine mounts. lol
Old Mar 31, 2009 | 07:32 AM
Dark_Teg's Avatar
I suggested deleting it and the wife said no cause she likes it. I think I have it figured out. I am going to remove the headliner and dynamat the hell out of the top and see if that helps. Maybe I can keep the vibration from ever getting to the sunroof.
Old Mar 31, 2009 | 08:54 AM
ridgeapd's Avatar
Its possible that the "squeaking" in your gauge cluster can be remedied by lubricating your speedometer cable.
Old Mar 31, 2009 | 09:49 AM
si vtec ftw's Avatar
EDM VT clusters tachs go to 9k and still are in MPH
Old Mar 31, 2009 | 11:47 AM
95gainfla's Avatar
how hard are they to find though?
Old Mar 31, 2009 | 01:34 PM
Dark_Teg's Avatar
I think I am going with a type R cluster to go with the type motor. I still have the electronic VSS from my old Integra so that will cut down the price of the swap some.
It looks like a real PITA to do the cluster swap but it needs to be done.
Old Mar 31, 2009 | 02:08 PM
crxjarred's Avatar
myn was squeeken too and i went to my parts car and found out it had a si cluster and it swaped out perfict lol and looks good it has bout 20k more miles tho but i dont care about the miles
Old Apr 1, 2009 | 06:23 PM
crxcommunity.com
if you own a crx, you better be on that site daily.
arigatocivic
16
Feb 20, 2009 05:19 PM
jdm_vtec
Dec 2, 2007 12:35 PM
emmo
Feb 24, 2003 07:27 AM
