what axles can handle large amounts of HP
Old Mar 31, 2009 | 05:30 AM
grkblood13's Avatar
Default what axles can handle large amounts of HP
I'm not really sure where to ask this since it deals with a crx with a prelude motor that uses accord midshaft, 88-89 integra axles and is FI but I'll try here, lol. My HP goal is to hit 600 and everything is strating to come together. The one thing I havent looked into is different axles though. With the midshaft and axles that I am currently using because of the H22 swap I was wondering is I could gather some suggestions on if I need to upgrade and if so what brand I should look into buying. Is Raxles the only place to go through?
Old Mar 31, 2009 | 06:06 AM
kyden's Avatar
Default Re: what axles can handle large amounts of HP
driveshaft shop.
Old Mar 31, 2009 | 06:44 AM
R.A.T.'s Avatar
Originally Posted by kyden
driveshaft shop.
x2
Old Mar 31, 2009 | 08:19 AM
h22a4_sol's Avatar
hasport .. which gets them from driveshaft shop .. i got a set of 475whp ones and they are great .. launching at 8k rpm and still holding strong ....
Old Mar 31, 2009 | 08:25 AM
cartunescivic's Avatar
www.a1cvtech.com
call them, ask for Marco, tell him Aaron told you to call. Tel:819-595-0400
they make my axles for both drag cars. AWD Audi, and VW. they make axles for Honda guys in the 9's with no trouble.
Old Mar 31, 2009 | 09:21 AM
Running925's Avatar
Stock
Old Mar 31, 2009 | 09:56 AM
E85B18's Avatar
Haha dont run stock. Ive broken 2 OEM honda axles with 430 whp, one was under boost in second gear, not launching! You are asking for a wreck with OEM axels and 500+ whp
Old Mar 31, 2009 | 10:06 AM
Running925's Avatar
thats funny.. i haven't had a problem & i've lauched the crap out of them with my slicks on.. guess preloading really does help.
Old Mar 31, 2009 | 10:31 AM
boostedcivicsir's Avatar
Mr. Badwrench
there are 2 kinds of people with stock axles, people that dont break them, and people that always break them. i hate fixing crap between rounds. and there are those that would rather break axles than trannies. im not one of them.
d.s.s. FTW
got my 5.9's from big tom NRG.
Old Mar 31, 2009 | 11:10 AM
E85B18's Avatar
How would pre loading or not have anything to do with breaking an axle doing a second gear pull?? Did you even read my post?
Old Mar 31, 2009 | 11:58 AM
northemt88's Avatar
one of my friends breakes her trannys but not her stock axles,she is on her 6th itr trans.480whp,she all ways pre loads
Old Mar 31, 2009 | 12:07 PM
E85B18's Avatar
Really??? Thats no good. Why is she using an ITR trans? GSR would be better with boost
Old Mar 31, 2009 | 12:25 PM
pgpbubble's Avatar
oh god.
not one of you people.
Old Mar 31, 2009 | 02:11 PM
96 GSR-T's Avatar
Originally Posted by pgpbubble
oh god.
LMFAO
I have 1500 miles on a set of Pep Boy's axles, 3 street tire passes and 2 slick passes at 550+ launching at 7500 and mine didnt break. However they kept me from making a 3rd pass as they coated my slicks in grease, and I was downright paranoid the whole time I had them on. To be honest I would rather do 150 in the quarter with not one lick of safety equipment than make another pass with stock axles.
For 600hp the DSS 3.9's seem to work great and I plan on using them for over 750hp. My friend is a tranny/axle killer and his 3.9's held 600hp/420tq for 40+ passes without an issue, I think the Evans's used the 3.9's in their old 9sec CRX, not sure if they ever broke them though.
Old Mar 31, 2009 | 02:21 PM
grkblood13's Avatar
ok, well earlier I talked to the guy a Raxles, i forgot his name. But anyways he said to run stock. He said that its a waste of money because of the angle that the axles sit at. He said the ones that are supposable bulletproof break just as often as the stock ones because of the angle they sit at, it has nothign to do wiht the material they're made of.
Old Mar 31, 2009 | 02:31 PM
northemt88's Avatar
she has like 4 itr
Old Mar 31, 2009 | 02:48 PM
E85B18's Avatar
Originally Posted by northemt88
she has like 4 itr
Ahhh that makes sense. I dont get it, I thought Raxles made high HP? Or at least ones that are supposed to be better than OEM?
Old Mar 31, 2009 | 02:55 PM
grkblood13's Avatar
well, they do make custom axles but they're not at the level of DSS. they're like $175 an exle.
Old Apr 1, 2009 | 03:22 AM
Mr. Badwrench
well i have a first hand experience that the dude at raxles is full of s***.
tried telling me that an inner cv joint cannot cause a vibration. i had a bad pair from him and they were shaking their *** off, and when i put in my dss level 1's the vibration went away, he said thats impossible. and him saying high dollar axles are a waste of money and dont do anything better than stock, wow
guess ill sell my 5.9s and get a set of his.
Old Apr 1, 2009 | 05:19 AM
Boostinb20!'s Avatar
Icon7 Re: what axles can handle large amounts of HP
I have to agree to go with stock although they make break from time to time but what doesnt when your pushing over 400hp. But again that is exaclty my point as well if you strengthen your axels something else is bound to break ...........Tranny hint hint. I would much rather replace an axel then tranny gears . I have seen several friends pushing well over 500 to 600 hp on the drag strip with slicks and have gone a full sean or two before they need to replace due to wear and tear not breaking.
Old Apr 1, 2009 | 07:30 AM
totsie7944's Avatar
Yea I've always been told proper preloading and you shouldn't break stock axles. You might not get the 1.4 60' times doing it that way, but you can def make use of slicks with stock axles with proper preloading and still cut good 60' times. I've seen someone shave off 2.5 seconds adding slicks because they spun so bad on street tires haha
Old Apr 1, 2009 | 08:01 AM
Ls_dx's Avatar
I have run stock (kragen reman) axles for 1.5 years in my coupe... 1.70-1.80 60 fts 9k rpm .. roughly 375 hp.. (b16) probably would be an issue with real power tho. DSS is worth the investment...
Old Apr 1, 2009 | 08:09 AM
tegman23's Avatar
Last year I put 150 passes on my 370whp stock axles, good preloading never had an issue...This year going for 500whp I upgraded to 500whp axles, just for peace of mind
Old Apr 1, 2009 | 10:29 AM
96 GSR-T's Avatar
I picked up 2 seconds from street tires to slicks on the first pass, after that pass I said no more street tire passes for me, its like trying to accelerate on ice when racing on radials.
Old Apr 1, 2009 | 10:50 AM
E85B18's Avatar
I know what you mean. I ran a 2.3 60' on my street tires lol
