water leak part 2
Old Mar 31, 2009 | 05:17 AM
spongecop's Avatar
Default water leak part 2
I stripped the entire interior out after my 95 Accord EX 4D became a bird bath on the drivers side. Once the headliner and trim was removed I can see water seeping from the seam where the roof meets the A-pillar. Water appears out of the seam, runs down the door seal and into the floorboard. I suspected it was the windo seal so I added some additional goo to the corner (inside and out). Did not slow down one bit. Had rain last night so I duct taped the window around the top and sides to see if that helped...no change.
Anyone have a similar issue? Thanks.
Old Mar 31, 2009 | 06:46 AM
AFAccord's Avatar
Default Re: water leak part 2
Where do you live? Some states will cover the cost of windshield replacement, which would be a great time to inspect that area if you suspect it's a sealing issue between the glass and the body. Just a thought.
Old Mar 31, 2009 | 06:59 AM
Carcrazy1
Guest
Posts: n/a
Obviosly yes! if the thing is damaged due to water seeping in then the seal is of a problem.
Old Mar 31, 2009 | 07:23 AM
spongecop's Avatar
I live in Dallas, TX. I will call my insurance provider.
Old Apr 1, 2009 | 11:19 AM
spongecop's Avatar
Working on this issue today I noticed something strange. With the sill plate installed in the drivers door, I can see a large stream of water entering over the plate and into the drivers floor. With the plate removed no leak.
Still have a seep from the top left corner running down the A-pillar, but that is not large enough to supply the leak I saw.
Anyone have any ideas..? Would make sense the door seal is failing but it looks ok.
Old Jul 3, 2010 | 01:37 PM
okiejen's Avatar
Icon2 Re: water leak part 2
Please forgive my ignorance. I'm having what seems to be the SAME issue with my 95 Accord EX. What is the A-pillar?
Thanks.
Jen
Old Jul 3, 2010 | 05:07 PM
accordlove's Avatar
its the piece of metal between the windshield and the side window.
CooperNOLA
Honda CR-V & Element
May 6, 2017 09:15 AM
kaboose79
Nov 22, 2016 07:43 AM
BiG_DeE
Jun 13, 2008 05:00 PM
awdgsx96
Oct 30, 2007 02:39 AM
swt_666
Dec 23, 2006 08:36 PM
