Brian Crower Stage 2 cams CRACK?
Old Mar 31, 2009 | 12:44 AM
slowtegkauai's Avatar
Default Brian Crower Stage 2 cams CRACK?
I just got a set of brian crower s2 cams and I read that their exhaust cam cracks because of the design of the vtec lobes. Can someone confirm this? I really dont want this cam in my head if its going to break and ruin everything. I also read that the vtec lobe binds with the LMA's which causes the cam to break. If this is all true, would a set of S2 S1 pro series be better? Someone please help.
Old Mar 31, 2009 | 04:16 AM
kyden's Avatar
Default Re: Brian Crower Stage 2 cams CRACK?
my friend has a set in his gsr, its been about a year now. its his DD, hasn't had any problems with it.
Old Mar 31, 2009 | 05:33 AM
PirateMcFred's Avatar
If you follow the instllation instructions specific for those cams and don't cut corners you should be fine.
Old Mar 31, 2009 | 10:56 AM
DcYo's Avatar
been rockin min for 3 years now. made 199whp w/ bolt ons and pistons
Old Mar 31, 2009 | 08:51 PM
Whats your setup? What compression you at? Its good to hear some people have no problem with thses cams. I just orderd a set of BuddyClub Spec III cams to use. Its less agressive than the Brian Crower stage 2 N/A cams.
Old Apr 23, 2009 | 02:43 AM
advaneh3's Avatar
looking into these cams too any info good/bad
Old May 1, 2009 | 03:59 PM
Mugen1320's Avatar
im also looking into these... any other info would be nice
Old May 1, 2009 | 04:17 PM
DcYo's Avatar
Setup
build was mild
b16 head stock
crower valve springs/ retainers
crower 402-2
bottom end was a stock GSR block w/ 11.1 Srp pistons
Bolts consisted of a Sparks racing tri y header /testpipe/ and apex n1 exhaust.
Cams peaked at 8500 rpm on my setup
Old May 1, 2009 | 08:17 PM
kyden's Avatar
there is a difference between crower and brian crower. the crower ones are the ones known to snap. i haven't seen a brian crower cam snap yet.
Old May 1, 2009 | 08:27 PM
mrbsponge's Avatar
correct, also the Brian Crowers are now being reported with many out of tolerance flaws, also i know its mitsubishi but AMS has stopped carrying and endorsing Brian Crower and switched to GSC.
In the latest cam tests BC made the least power
Old May 2, 2009 | 05:29 PM
Rollo Lawson's Avatar
b.crower 2's are a good cam that makes good vtec power, whereas the bc3+'s make monster low-mid with very comparale top end. op, pm me and i'll shoot u a few charts from my build. b.crower 2's made 199whp, 143wtq. bc3+ 196whp, 141wtq, but the 3+'s made more average power from 3-8k
Old May 3, 2009 | 09:26 AM
jspeccrx91's Avatar
had my brian crower na stage 2's for about a year now with no problems.
b16 11.7cr 191whp, only negative is max power @ 8600 but that's mostly because of my p/p and other mods.
Old May 3, 2009 | 12:18 PM
Well I wont be using my Brian crower cams. If any one wants to buy it Ill do $420 shipped from Hawaii. I bought it for $460.00 and never took it out of its plastic bag. PM me if any one is interested in buying brian crrower stage 2 N/A cam.
Old May 3, 2009 | 06:25 PM
turbociv910's Avatar
No problems here when I tuned a set of bcIIIs
Old May 3, 2009 | 06:48 PM
gutted-dx's Avatar
I've had both of the Crowers for over a year and no problems yet with them. Sorry to hear your not using them, Good ****!
ratski
Engine Machining & Assembly
Jan 19, 2019 09:28 PM
VTIargentina
May 29, 2010 07:54 PM
eg:R
Dec 16, 2009 04:22 PM
IamVtec
Jul 6, 2009 06:01 PM
92 civic VX B18c
Oct 10, 2003 10:51 AM
