Pistons?
Old Mar 30, 2009 | 11:08 PM
alanizda90's Avatar
New User
Icon6 Pistons?
Im planning on boosting my ls but im not sure on what type of pistons to throw in. Anybody have any good suggestions?
Old Mar 31, 2009 | 08:49 AM
boarderwayne's Avatar
Default Re: Pistons?
use the search button and start reading, these things have been covered a million times but people keep asking the same questions
Old Mar 31, 2009 | 09:21 AM
Zappythebum's Avatar
whispers 'low compression'
but yeah there's a ton of topics on this
Old Mar 31, 2009 | 10:56 AM
ivan93egreppin210's Avatar
depends on what your hp goals are. i live by culebra and 1604. im sending you a pm with my number if you need real advice and help with deciding a good setup.
Old Mar 31, 2009 | 11:21 AM
ray on boost's Avatar
13 to 1 compression wiseco or je pistons and atmospheric pressure. turn your wast gate to that
Old Mar 31, 2009 | 11:22 AM
A.E Motoring's Avatar
most common is 9:1 forged pistons
Old Mar 31, 2009 | 11:23 AM
Brice.Hayden's Avatar
def dont listen to this clown^^^^
some OEM GSR P72 pistons will work well or some aftermarket 10:1 will work great. Wiseco or CP are good brands.
Old Mar 31, 2009 | 11:32 AM
dude you should be banned for giving an anser like that unless thats what you really think. if your being sarcastic then say so. ...........
TO THE ORIGINAL POSTER....... 13 to 1 pistons are too high a compression piston for even an n/a motor without proper tuning/ high octane gas (over 93) and major internal mods. you need to be in the 8-9 range on you compression. by compression i mean overall compression after all mods/head milling/block decking/head gasket thickness. pistons compression alone will not dictate you over all compression.
Old Apr 1, 2009 | 04:54 PM
00IntegrAllmotoR's Avatar
HT Black OPs
CP 9:1, 81.5, is what i got.
Old Apr 1, 2009 | 05:38 PM
MumBleZ_94gsR's Avatar
10:1 cr forged pistons are prolly ur best bet...but it all depends on how much power u want to put down...lower compression tends to be more reliable with boost
eyji-
Jan 20, 2010 12:31 PM
wesley_925
Mar 31, 2008 08:44 AM
masteryoda10
Jan 30, 2006 04:30 AM
grimple1
Mar 20, 2004 12:25 PM
TurboT
Nov 28, 2001 01:42 PM
