"Automatic Down" Power Window Switches
Old Aug 14, 2002 | 06:10 AM
Blockhead G's Avatar
Default "Automatic Down" Power Window Switches
I would like to make the passenger side power window switch (on the driver's door) automatic like the driver's side window.
You know, when you tap the switch the window comes down all the way and stops automatically without sitting there and actually holding the switch down.
Cheers
Old Aug 14, 2002 | 06:30 AM
greensleeper's Avatar
Default Re: "Automatic Down" Power Window Switches (Blockhead G)
Its not in the switch per say (yes the switch has an extra pin) but in the magical black box.
You can tear it all apart and try to make it work. Or you can get a power window module to work with an Alarm. Mine is from DEI (Viper) but I'm sure other alarm manufacturers have similar products. From my remote I can lower, raise, and vent (bout 2 inches at a time) both windows. And it gives the drivers side switches one touch control up and down.
NOTE: most units will only control two windows in two directions or four windows in only one driections.
[Modified by greensleeper, 10:30 AM 8/14/2002]
Czapsiu
Jun 9, 2018 07:54 AM
96blkteggy
Mar 19, 2011 03:19 PM
velocity101
Nov 1, 2008 10:45 AM
accordinglyevil
Audio / Security / Video
Mar 11, 2008 05:44 AM
