It's time for rebuild EF/d16a6...
hey guys its been a while i haven't posted anything here well here i decided to build my ef after its been long 6 months on my drive way due to a bent valve and in need of new clutch and fly wheel...
earlier i was planning to pull the head cylinder out earlier but im still a nooby on this it took me 4 hours just to get the head cylinder ready to be pulled out, then i found out a lot of problem under the car i saw oil+tranny fluid dripping everywhere. So i decided to rebuild my whole engine and clean all that nasty oil tranny fluid under the car and beside i need to rebuild the front end of my car due to an accident that happen last year. So i have question to ask can someone give me a write up of how to take off an engine on my 90 Si civic. so here are some pic of what i did earlier i really need help on this one guys im new at rebuilding engine and frame of the car...
its been sitting down there for 6 months
what i did earlier
idk tried to take the head cylinder
that is what my car look like after the whole day hehe
what i did earlier
The service manual is basically 90% pictures and diagrams, what specific questions do you have that we can clarify?
like there is some part that i need to unhook and it says on the manual and i dont see it on the picture or i dont know where its located but here's the question what else do i need to take a look and make sure that is not connected before i go ahead and take the head cylinder off.
Just dive in man its really all common sense. Unhook all wiring, fuel lines, shift linkage, exhaust, axles etc...remove everything in the way Radiator, alternator etc...
Latch onto engine with Cherry picker and carefully remove it.
Bag and label all bots. Be safe!!!!!!!!!!!
I wouldnt invest in anything more untill i got a basic understanding of removing parts.
i have the shop manual that i download months ago thats actually what im using it has a lot of stuff in it and its hella thick i guess im using the right manual for my car... thanks for the advice too
it looks like its really bad
do i need a new piston also?
dang oil build up
my fuel injector it has oil inside wth?!?!
my cylinder head
bent valves
so my next step is to clean this and later on take the tranny out and the block, any suggestion please feel free to tell me what do i need to do i need help on this guys
THANKS...
hey good luck with the rebuild. im just about to finish mine. if you wanna see any pics or have any questions. PM me and/or check out my build thread in my sig
so here is the update i just cleaned my fuel injector and i found a brake cleaner that cleanse the build up oil inside it did a pretty good job but i know its not for that but it works so here are some pics
before the clean up
the build up oil
now after clean up
closer look
its 1:38 pm and its still early but im low on budget that made me stop rebuilding and oh yeah do i need to get a new fuel injector since it has 200k miles already?
before the clean up
the build up oil
now after clean up
closer look
i just finish cleaning my head cylinder and i checked if there is a bent valve but it turns out that there wasnt a bent valve its just my camshaft gear is loosen and thats the reason why my car isnt working, and when i went to the shop they told me its a bent valve what a rip off. while checkin my valves i accidentaly lost the lock for the valves where can i get this i only need the 1 of the half of the lock and should i go change my valves too? need help guys
update for my project had a hard time taking the freakn axle nut, end up taking the axle while the disc rotor stuck in it and bringing it to the shop to get it off. and mail drop something for me and ive been waiting for this for a long time.
opened the box and saw this
LOL they gave me candy as for thank you hahah sweet!!!
the whole HID kit
new slim HID kit
and some stuff that came Rev3 t-shirt and team t-shirt just throwing out there for fun
i got hungry after working on my car YUMMYYY!!!!! hahah
the whole HID kit
new slim HID kit
