idle trouble
Old Aug 14, 2002 | 04:37 AM
96_GSR's Avatar
Default idle trouble
I have the Skunk2 Stage 2 cams along with a VAFC. When I got it dynoed, it idled fine. I installed a Skunk2 chip, and put the VAFC back to default, so I didn't run lean. I just installed a new Exedy clutch and Toda flywheel (which I love by the way), and now the idle goes to down to like 400, and bounces back to 800..It happens intermintenly. My cam gears are at 0,0. What could be causing this? I going to get it redynoed this Friday. Should that correct it?
thanks
Old Aug 14, 2002 | 04:41 AM
sohc_boy's Avatar
Default Re: idle trouble (96_GSR)
did u chk for vacuum leaks?
Old Aug 14, 2002 | 05:25 AM
96_GSR's Avatar
Default Re: idle trouble (sohc_boy)
No I haven't. How exactly do you perfom that test?
Old Aug 14, 2002 | 09:18 AM
sohc_boy's Avatar
u can take some carb cleaner and spray it around the intake manifold and various hoses that are attached to it, if there is a leak the engine idle will fluctuate a lil. since it will be able to suk the carb cleaner in from the leak where u sprayed it. forgot to say with the engine running.
[Modified by sohc_boy, 1:19 PM 8/14/2002]
94vtirozguy
Nov 17, 2009 04:43 PM
milton
Feb 3, 2006 08:01 PM
VTEC Visions
49
Sep 3, 2005 11:19 PM
cs_x21
Jun 25, 2003 03:54 PM
amrintegra
Dec 9, 2001 12:18 PM
