H23 wont start/replaced head gasket? Help
i just replaced my head gasket on my h23a1 and i tourqed all head bolts to specs,timed it perfectly changed spark plugs to correct firing order on distributor checked all vaccum hoses and wires and hoses, cant find anything! it sounds like a honda turning over but wont start. any ideas anyone?
check and re-check EVERYTHING you did,
reattach ground wires?
all sensors pluged back in?
distributor pluged in?
check rotor and cap
check spark plug wires are correctly pluged in
check rotor and cap
when i had the firing order firing 1234 the car ran but ran like **** but when i switched firing order to 1342 the car turns over great but no start. any other ideas? its got 2 b something simple
How'd you manage that? They're keyed so they only slide into the cam correctly, unless you put the rotor button on backwards, which can happen on the older ones that aren't keyed
96Formula6spd
Mar 4, 2011 08:58 PM
the king.
Jun 27, 2008 11:36 AM
drifterX420
Jul 11, 2007 12:47 PM
