Stock Compression H22 and E85
Old Mar 30, 2009 | 12:56 PM
JayWest's Avatar
Default Stock Compression H22 and E85
Just wondering if any of you think there would be any downside to running e85 as opposed to 93 pump on a stock block H22 setup.
The car is not a daily driver and will also be on nitrous. I would prefer to keep it e85 when running all motor as well.
I understand I would benefit more from the e85 with higher compression but im assuming i would still see a greater result over pump gas.
Any insight would be appreciated
Old Mar 30, 2009 | 06:45 PM
H24A96EK's Avatar
Default Re: Stock Compression H22 and E85
you will make the same power either way. is all in tuning. safer to go with e85 with nitrous due to the higher octain rating however you will be running more fuel to do so.
Old Mar 30, 2009 | 07:24 PM
GoldLudeRay's Avatar
he said it all
the aera when pump is starting to not shine as high as e85 is 12.0.1cr
THEhomelessONE
11
Nov 23, 2018 05:16 AM
lude98SH
43
Jan 16, 2007 07:38 PM
cpmike
Jul 31, 2006 10:41 PM
stylieee
Mar 28, 2005 03:49 PM
jdmlude01
Jan 7, 2005 03:44 PM
