Help on JDM HEAD LIGHTS!
Old Mar 30, 2009 | 09:35 AM
zcmotor's Avatar
Icon7 Help on JDM HEAD LIGHTS!
Can someone tell me on how to wire a jdm headlights they are like so different connections than the stock us headlights.
Old Mar 30, 2009 | 09:53 AM
creepass's Avatar
Default Re: Help on JDM HEAD LIGHTS!
i used eg headlights.. and wiring
Old Mar 30, 2009 | 09:54 AM
Canadian_EF's Avatar
the connectors are different.
you have to splice in the wires...
did you get the bulb wiring harness's too?
Old Mar 30, 2009 | 10:00 AM
si vtec ftw's Avatar
attach your high beam power wire to the eg light harnesses high wire, and the low to the low and take the two grounds and connect them to the one ground on the eg harness
try that one guy
Old Mar 30, 2009 | 10:04 AM
haha. i got owned.
i gotta remember that for when i do my edm headlights...
Old Mar 30, 2009 | 10:37 AM
zcmotor's Avatar
they are 89 crx jdm headlight and so the jdm ones haves like 2 or 3 wires and its only. its not like the us head light where u usually have the high beam connecter and the regular connection
Old Mar 30, 2009 | 10:42 AM
try that one guy
that is all you need ot know. I will umm... spoon feed you.
1. Label all of the wires from both usdm headlight harnesses (grounds, high beam, low beam)
2. Cut the harnesses off.
3. Connect the grounds together, splice with the grounds from the JDM headlight harness.
4. Connect the high beam wire to the JDM high beam wire.
5. Connect the low beam wire to the JDM low beam wire.
6. You should be done. Have a beer or a smoke or something. That was some hard work...
Old Mar 30, 2009 | 10:51 AM
zcmotor's Avatar
alright thanks ill be working on it today then. this jdm front end was a hassle to put on also...lol
Old Mar 30, 2009 | 08:14 PM
haha there ya go
dumbed it down for ya
should have got an eg.
if you gonna try and be an ef owner, youre not about to complain.
its the shittiest front end to take apart and put together than any other civic ive ever worked on.
Old Mar 30, 2009 | 08:29 PM
creepass's Avatar
it was not hard at all for me, just takes time.
Old Mar 31, 2009 | 08:24 PM
really you just gotta watch on the bolts by the door, i scratched up my new paint on my doors cause i was impatient about it, but really its just a car, its going to get scratched and banged.
civichobby
Jun 25, 2007 01:42 PM
1904 Spugen EJ1
Jun 2, 2007 04:51 PM
SpleenBoy
Jun 7, 2006 12:07 PM
dingusjt
Jun 9, 2004 04:55 PM
