Low voltage in '99 Civic
Old Mar 30, 2009 | 07:35 AM
EX-T's Avatar
Default Low voltage in '99 Civic
I've noticed over that past week or so that the voltage when the car is running is around 11V and sometimes it jumps up to 12.8V and sometimes over 13V.
Does this mean I need a new alternator because of a bad voltage regulator?
Also, the car starts normally (it doesn't crank slow or anything)!
Old Mar 30, 2009 | 08:46 AM
Vindicator9000's Avatar
318 Curves, 11 miles
Default Re: Low voltage in '99 Civic
sounds low... both my cars have always ran around 14-14.4 consistently. Not sure if that's a sign of a bad alternator, but it definitely seems lower than normal.
Old Mar 30, 2009 | 09:01 AM
hondamark35's Avatar
most autoparts stores can test for a bad alternator.
that voltage sounds fishy, but i wouldn't try fixing something untill you know what's broken... or if it's broken.
find a place that can do a "starting/charging" test. this will give a difinitive answer.
integra15
Dec 15, 2011 09:02 PM
milkwasabadidea
Sep 2, 2011 02:11 PM
manyakiexpi
Oct 24, 2006 04:57 PM
. M i c h a e l
Dec 4, 2005 09:50 AM
ck279
Oct 12, 2001 05:27 PM
