CEL came on last night...what could it be?
While on my commute home from work, ! My check engine light came on! Seems to be running fine. Although it 'maybe' ideling higher than usual. I pulled over and tryed to find anything wrong, but with low lighting and it being night time, plus not knowing what to look for I couldn't fix it. I turned it off and back on, all gone until maybe 10 miles and it came back on again. Could it be a loose wire, I'm guessing it is the knock sensor wire but I can only hope that is the only case.
What could it be? HELP! TIA
I would but how do you do that!?
If it's as easy as turning it to the 'ON' position and waiting for the check engine light to blink? and count to see how many times to find the code, it didn't do so. Then again, shoot, I don't even know what to do which is why I ask for help
TIA!
TIA!
bigodub93
20
May 19, 2010 01:49 PM
ph0shizzle
May 13, 2006 08:36 PM
Thagreybomber
Aug 22, 2002 11:02 PM
