timing
im confused, looking down at the crank pully there is three groove lines and a space then 2 groove lines which ones do i line up with the piece on the lower timing belt cover??? please i need help with this
seems like every time i adjust every thing, then i turn the timing light on and its back to the way it was when i started
well its not my timing i just had a shop set it perfect and still runs like **** they said it is a burnt valve......would a burnt valve make my car back fire(some times flames) and loss of power and bogging????
possibly, did you ask them how they came to that conclusion?
well the car use to over heat and it did skip a tooth in timing so it burnt the valve while it was open wen it should have been closed i guess.......that is the only thing left to this wonderful mystery
1990civicdx
Jul 17, 2018 06:13 PM
Cams are at TDC and crank is at TDC, but when I hit it with the timing gun it shows the white line l
Thrillhouse
Aug 7, 2004 01:13 PM
