how do you change the climate control bulb?
Old Mar 29, 2009 | 08:15 PM
doubleoazn03's Avatar
Default how do you change the climate control bulb?
My girl just got a dc5 and her bulb for her climate control is out, how do you take out the face plate of the climate control and get those ***** off? what bulbs are they? and what is the bulb size of the front blinkers on the headlights?? I need to change those too
Old Mar 29, 2009 | 08:39 PM
darkstarsinner's Avatar
Default Re: how do you change the climate control bulb?
http://www.sylvania.com/ConsumerProd...lacementGuide/
For you blinker bulbs and others you may need to replace.
How to remove the cluster:
Heater Control Panel Removal/Installation
NOTE:
When prying with a flat-tip screwdriver, wrap it with protective tape, and apply protective tape around the related pants, to prevent damage.
Take care not to scratch the dashboard and related parts.
Gently pry up on the heater control panel (A) to detach the clips (B, C) and to release the hooks (D), then pull out the panel.
Disconnect the climate control unit connector (E), then remove the panel
Now how to get to the bulb itself:
Climate Control Unit Bulb Replacement
Discharge the static electricity (which accumulated on you when you removed the climate control unit) by touching the door striker or other body parts.
Remove the self-tapping screws, then carefully separate the climate control unit to the display (A) and the control unit (B). Do not kink or pull on the wires between the display and the control unit. Do not touch the electronic components on the printed circuit board in the control unit.
Remove the bulb(s) with a flat-tip screwdriver.
Install the bulb in the reverse order of removal
Old Mar 29, 2009 | 08:40 PM
Dissregard the removal of the ****. You shouldn't need to do that.
Old Mar 29, 2009 | 11:08 PM
tweek_boii's Avatar
Hands down for darkstarsinner.
Old Mar 30, 2009 | 02:21 AM
lol
Old Mar 30, 2009 | 09:59 AM
Perfect, thank you; just what I was looking for.
Old Mar 30, 2009 | 12:31 PM
N/P man. Let me knwo if you need anything else.
Old Apr 1, 2009 | 06:30 AM
lev16gt's Avatar
Yes, nicely done my man! I've had my new car for about 7 weeks now and have been too lazy to do this...now maybe I'll get off my *** and do it.
Ohio FTW!
Old Apr 1, 2009 | 01:29 PM
Lol Ohio's the **** when it's not snowing.
Old Apr 2, 2009 | 11:57 AM
DTR920's Avatar
New User
nice
Old Apr 2, 2009 | 01:48 PM
If you guys need help with anything else just make the thread and send me PM of where it is, I'll help the best I can.
Old Jul 13, 2009 | 10:57 PM
spoonsol's Avatar
New User
might you have one of these for a 93 del sol climate control?
Old Dec 21, 2014 | 08:25 AM
shafeen21's Avatar
I know this is unrelated but does anyone know where I can find just the turning ***** for the climate control as one of them were broken/missing when I bought my 2002 RSX. I looked all over amazon, eBay and other places online with no luck. I was told that you could easily find them but so far, no luck!
Old Apr 15, 2019 | 02:45 PM
Jeremy Perez's Avatar
NOTE:
Could someone provide the Honda Item number to those two light bulbs? I'm pretty sure there are 2 kinds here and I only know the one that comes in a pair.
Old Feb 11, 2020 | 09:14 AM
yossi's Avatar
So two bulbs will light up all three buttons?
Old Feb 12, 2020 | 05:47 AM
NDNV's Avatar
Yes 2 bulbs illuminate the 3 panel buttons. I would replace both even if one still works.
Old Feb 12, 2020 | 05:59 AM
yossi's Avatar
THANKS! One more question - - is this to replace the orange light that goes on when you press the button, or the background light that illuminates the button itself so you can see what the button says?
Old Feb 13, 2020 | 08:03 AM
tommycrx's Avatar
Background lighting. Those little slits fro recirc, a/c, and rear defrost are inside those buttons. Swapping them out would be a huge PITA.
Old Apr 11, 2020 | 11:52 PM
7PSI CRX's Avatar
Recently heard that our good friend Tom has passed due to COVID-19
Kept his car till this day
Ride on Brother Tommy!
Old Apr 13, 2020 | 11:05 PM
TheRickster's Avatar
Woot Ohio...
There are some nice plastic interior trim tool sets on Amazon if you want to get some things to help you pry that stuff out that will be a lot more gentle with the dash and plastic trim parts. You can still break stuff, but it's not really expensive at all and Mine comes with like 10 tools for 20 different types of pry/working ends.
mikej94civex
Jan 26, 2010 01:18 PM
eluam
Dec 2, 2007 10:55 AM
zertoir
May 1, 2004 06:41 PM
SupaTegRS
Jan 8, 2003 09:51 PM
