D15 plug gap question
I have a jdm D15
I just bought some NGK plugs and wires. But i looked up the gap and im getting conflicting results.
It says on one site the proper gap for si model is .052 but this is for a b16a. I have a D15 jdm with vtec
A non vtec D15B7 is supposed to have a gap of .o44
Am i supposed to go by the b16 specs since i am running vtec?
Can any one give a link to more info or know off the top of their head?
My car only comes with a b16 in the usa. But i have a jdm D15 in my car. All the charts showing gaps i could find are for US Domestic models.
My engine is reletively the same size but it is a vtec so it stands to reason a different gap would be needed.
Anyone got any more input on this matter?
Your spark plug gap has more to do with compression than anything else. As the pressure increases, it's more difficult for the spark to pass between the two electrodes. This is the same reason that boosted engines need a tighter spark gap or a higher voltage coil. I don't feel like looking it up, but I would assume that the B16 uses a different spark plug, necessitating a different gap. Someone correct me if I'm wrong, but I haven't heard of any differences between the D and B ignition systems, as far as differences in voltage.
I say that since the D15B has the same compression ratio as the D16Y8 (9.6:1), run the same gap the D16Y8 calls for; .043in. I figure this because they are both SOHC VTEC engines. But wait, you're only talking 1/1000 of an inch difference between the D15B7 and D16Y8. You're fine, run .044/.043 and it shouldn't matter.
From what i have read , The jdm D15 has a higher compression then the d16. So with more compression/smaller gap school of thought we are probably good with .044
Thanks for all the input guys. It's been a big help.
jdm.boi408
Oct 24, 2010 07:02 AM
Project_ED8
Dec 2, 2003 08:12 PM
