Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
suspension issue?
Old Mar 29, 2009 | 04:45 PM
jonssonar's Avatar
Default suspension issue?
I have a 2006 EX coupe, purchased November 2005. I've noticed that my front left side makes a "thunk" noise occasionally when I hit a bump. I haven't messed with the suspension or anything... stock suspension on SI rims with low profile tires. Its not a constant, over every bump, but still worrisome. Happens two or three times a day. Anyone have an idea what it might be? Today I took it through a soft-cloth car wash, and going down the ramp to the wash, it made a slamming noise at the bottom of the ramp.
Old Mar 29, 2009 | 05:07 PM
vladd's Avatar
Default Re: suspension issue?
it's an issue with the bump stop, if you still have the warranty they'll probably end up replacing the strut.
Old Mar 30, 2009 | 12:21 AM
jonssonar's Avatar
Thank you for the input. The car is no longer under warranty. Shouldn't be an expensive fix, I hope?
Old Mar 31, 2009 | 07:18 PM
vladd's Avatar
did it start out as a 'pop' and progress to a 'clunk'? that's what happened to mine, i've read up on this on 8thcivic about this and it's usually an issue with the bump stops. if the bump stops are replaced in time i think the shocks can be saved, otherwise the shocks will also need to be replaced. i don't have warranty either; i'm solving my problem by getting full coilovers
k_lude
Nov 16, 2009 09:55 PM
dfoxengr
Suspension & Brakes
22
Sep 23, 2008 11:45 AM
95AccordDX
Mar 23, 2004 04:45 PM
Humlae
Feb 25, 2004 05:09 PM
Robo_Wop
Jun 21, 2003 09:57 PM
