New civic hatchback PROBLEM with shaking.
Old Mar 28, 2009 | 10:14 PM
jdmjoka's Avatar
DB squad #282
Icon3 New civic hatchback PROBLEM with shaking.
I just bought a civic hatch back has a LS integra motor with hassport mounts. When you drive the car vibrates. and you can hear like thumping down at the wheels sorrta when ur out side of the car. The brakes are WARPED. could this effect when you actually drive the car without hitting brakes? like would they make noises?
Old Mar 28, 2009 | 11:09 PM
b16_sol_707's Avatar
Default Re: New civic hatchback PROBLEM with shaking.
if the rotors are warped really badly it can cause the car to shake all the time.
Old Mar 29, 2009 | 12:28 AM
jdmjoka's Avatar
DB squad #282
i think they are lol
Old Mar 29, 2009 | 12:38 AM
trustdestruction's Avatar
get some new rotors
Old Mar 29, 2009 | 04:05 AM
AznKid_D16y8's Avatar
New User
Maybe your eng. mounts are bad?
Old Mar 29, 2009 | 12:24 PM
He has hasport mounts... I really doubt they are bad.
OP: are your tires balanced?
and like I said before, definitely get new rotors (and pads of course)
Old Mar 29, 2009 | 01:59 PM
EJ6JON's Avatar
If I were the OP I would replace rotors and pads also balance tires if they arent already!
Old Mar 29, 2009 | 02:02 PM
Redbone's Avatar
the car may be vibrating because of the mounts but the brakes need to be replaced regardless due to the warped rotors
Old Mar 29, 2009 | 02:45 PM
He said shaking though. The mounts won't make the car shake, just vibrate.
Old Mar 30, 2009 | 08:58 PM
Redbone's Avatar
reread the first post he says VIBRATE which would most likely be just because of the aftermarket mounts but the shaking is the brakes or a balance and alignment issue as well
kyalstyle
22
Feb 22, 2009 07:27 AM
L8APX
24
Nov 29, 2008 10:10 AM
19992civichatch
11
Jan 10, 2007 10:42 PM
EK9 BEEZLER
Jul 25, 2005 04:44 AM
BlackOut21
Jan 7, 2003 10:37 AM
