Checking valve clearences B20/b16
Old Mar 28, 2009 | 07:40 PM
paulr5's Avatar
New User
Default Checking valve clearences B20/b16
Building a street b20 with a b16a head with ITR valves, ITR valve springs and ITR Cams and a port and pollish,
Its well documented the b20 v-tec and clearence should be no issue? but fools rush in so.....
The issue i have is i want to clay the crown of 1 and 2 piston and check the clearence but how do i equate for the v-tec lift?
also I plan on using the above set up on a stock b20z1, re-newing the crank seals, sump seals and baffeling the sump (while off) any draw backs on using the stock block with no modifications, i.e. is the stock oil pump up to the job? also is an oil cooler any obvious advantage?
Old Mar 28, 2009 | 08:26 PM
Combustion Contraption's Avatar
Default Re: Checking valve clearences B20/b16
Take a look in the FAQ that is stickied at the top of the forum for a how-to on P2V which covers locking VTEC.
vyrus
10
Feb 15, 2012 09:19 AM
vtecJUNior
May 8, 2008 02:40 PM
darkintegra
Jul 11, 2007 05:53 AM
b20bvtec'd
Nov 22, 2003 07:24 PM
