Main Bearing halves....not fit all the way in the block..
Old Aug 13, 2002 | 09:19 PM
Flamenco-T's Avatar
Default Main Bearing halves....not fit all the way in the block..
is that normal ? I have ACl bearing set and the main ones on the block and one part of the bearing stick out slightly, enough to catch my finger nail when I run my finger to wait..
the other ones is very flush to the block..
should I just keep trying to push it in to make both sides flush evenly...?
thanks
stan
Old Aug 14, 2002 | 08:25 AM
earl's Avatar
Default Re: Main Bearing halves....not fit all the way in the block.. (Flamenco-NA)
If they stick out, they're not in all the way. Try installing the main cap without the crank and it should straighten out. If you are not sure, bring it by my house and I will help you.
Old Aug 14, 2002 | 09:12 AM
CHEETAH's Avatar
is that a joke in your signature ? 9:1 je pistons for a rotary motor ?
Greg
Old Aug 14, 2002 | 09:16 AM
kenji's Avatar
25 Year Member
Default Re: Main Bearing halves....not fit all the way in the block.. (CHEETAH)
Greg,
You know he is serious. And if anybody buys those pistons for a rotary motor I have some great cams and valves for them.
-kenji
Old Aug 14, 2002 | 06:37 PM
Flamenco-T's Avatar
Default Re: Main Bearing halves....not fit all the way in the block.. (earl)
thanks Earl...
I am gonna try to push them again, just to make sure the bearing halves is all the way in....
I'lllet you know
thanks again
Old Aug 14, 2002 | 06:42 PM
GruvyTune's Avatar
New User
stan,
i got the acl std bearings for my gsr and they fit in fine.
all were within the spec limits. some closer to tight some closer to loose, some in the middle but still all within spec. they seated in there just fine.
Old Aug 14, 2002 | 06:44 PM
GruvyTune's Avatar
New User
earl,
i'm finding i hear a slight clicking sound at very low idles. it seems to go away at faster speeds. can it possibly be a bearing problem??? is there a way to tell before something bad happens? i have about 950 miles on my rebuild now with je 9:1 , eagle rods and the acls
Old Aug 14, 2002 | 07:37 PM
earl's Avatar
Default Re: Main Bearing halves....not fit all the way in the block.. (GruvyTune)
If it's a click, could be something like noisey injector, valve train, selenoid, waterpump or? Bearing would be more of a deep pounding clang. How's your oil pressure at idle? Hard to say what it could be without hearing it. Might try disconnecting spark plug wires one at a time to see if the noise would go away. That would isolate it to a particular cylinder if it was a piston slap or rod bearing or wrist pin related. Let me know.
Comp97GSR
May 18, 2012 07:17 PM
white4doorsi
Jul 6, 2008 01:05 PM
jordan2305
Mar 18, 2008 06:38 PM
rmcdaniels
Aug 6, 2005 04:13 AM
VWkila
Feb 22, 2003 10:47 PM
