Turbo D16Z6
Old Aug 13, 2002 | 09:17 PM
Blue_Si03's Avatar
Default Turbo D16Z6
Can't find it on search, how much boost can a D16Z6 handle on stock internals. Is it like the ZC at roughly around 200hp?
Old Aug 13, 2002 | 09:31 PM
.nate's Avatar
Default Re: Turbo D16Z6 (CRXracer89)
we hit 15 lbs a couple of times with alot of fuel and stock internals on my buddies z6.. threw every code in the book and clipped the 310's tho lol
Old Aug 13, 2002 | 09:57 PM
blackEF's Avatar
Default Re: Turbo D16Z6 (N8)
220 hp then the rods go....so whatever gets you up to there
Old Aug 13, 2002 | 10:12 PM
ViperRedCRX's Avatar
yeah, my car has hit 15 a few times, but i run 10psi daily on stock internals, with a decent fuel system
Old Aug 14, 2002 | 04:15 PM
td04civic's Avatar
Default Re: Turbo D16Z6 (Zit)
yeah, my car has hit 15 a few times, but i run 10psi daily on stock internals, with a decent fuel system[/QUOTE]
Could you post the set up that you're running and maybe some pics of it.
Thanks
Troy
Old Aug 14, 2002 | 04:37 PM
ImportHatch's Avatar
Default Re: Turbo D16Z6 (td04civic)
im putting together a kit right now. Cant wait to get it on.
Yager-
Old Aug 14, 2002 | 04:53 PM
Thanks
Troy
hf manifold
ford probe turbo
homemade piping
drag II fmic
dragII fmu w/8:1 disc
nos 255lph in-line pump
rc 310's
[Modified by Zit, 7:58 PM 8/14/2002]
Old Aug 14, 2002 | 05:14 PM
Timmah!!'s Avatar
Hey is that probe turbo that little IHI
And if it is how much is it worth???
BTW Love the "junk yeard" turbo setup
Old Aug 14, 2002 | 05:57 PM
Default Re: Turbo D16Z6 (azroth)
the little ihi's aren't worth **** as far as i'm concerned...they make good boost on sohc's, but they fun out after about 6600rpm...and they are a dime a dozen a junk yards
thanks
Old Aug 14, 2002 | 06:32 PM
Timmah!!'s Avatar
what about brand new ones???
I got 3 of them just sittin and would like to sell them (even if its for like 100-200 bucks)
Old Aug 14, 2002 | 06:34 PM
if they are 100% new, you may be able to get like $100 or so for them off ebay
Old Nov 6, 2002 | 11:14 AM
NonovUrbizniz's Avatar
Loved
even the little ihi's sell for 100 bucks on ebay regardless of condition
Old Nov 6, 2002 | 12:13 PM
TypRice's Avatar
i never hit over 12psi!
Old Nov 6, 2002 | 01:09 PM
BoostedED9's Avatar
Default Re: Turbo D16Z6 (TypRice)
i just finished my turbo z6 setup and right now im runnig 6.5lbs but soon im gona bump it up...
Old Nov 6, 2002 | 01:47 PM
TypRice's Avatar
Default Re: Turbo D16Z6 (BoostedED9)
i think i blew my motor?!
Old Nov 6, 2002 | 03:10 PM
BoostedED9's Avatar
i hate my car... beat that
Old Nov 7, 2002 | 03:44 PM
TypRice's Avatar
OK i think i can...
if the car isnt running by next week...im going to burn it!!!
Old Nov 7, 2002 | 05:28 PM
BoostedED9's Avatar
OK i think i can...
im just about at that point with mine... you wanna put the cars together and make a big fire and throw a party
Old Nov 8, 2002 | 05:09 AM
D16Z6racing's Avatar
I'm running stock, 4psi, boost with my GReddy kit on my D16Z6. Won't go over 6psi on stock internals. Plus I'm not using an IC so I can stay in a sleeper mode.
Old Nov 8, 2002 | 05:55 AM
88EF's Avatar
Default Re: Turbo D16Z6 (buster13)
More like so you can stay in cheap *** mode.
Old Nov 8, 2002 | 07:35 AM
kranked91dx's Avatar
Default Re: Turbo D16Z6 (88EF)
the fact you are not using a IC won't give you a "Sleeper mode"
Look at Sir kid setup, this is a sleeper, got max performance without having to sacrifice look.
then just get an intercooler mounted Inside the front bumper behind a grill or anithing else, Other think you'r a ricer cause you got cheap *** grill in front but you can kick their *** anytime !!
Old Nov 8, 2002 | 07:55 AM
CWBETB's Avatar
Default Re: Turbo D16Z6 (kranked91dx)
SLEEPER MODE!!!
Old Nov 8, 2002 | 08:20 AM
irtep's Avatar
Default Re: Turbo D16Z6 (CWBETB)
running 10 psi on stock internals. d16z6, greddy kit (custom piping), fmic, 89 integra ecu, msd rpm switch (vtec) and paxton boost dependent fpr.
Old Nov 8, 2002 | 09:56 AM
VTC_CiViC's Avatar
Default Re: Turbo D16Z6 (blackEF)
Rods can hold well over 220, it's the ring lands I'd be worried about.
Old Nov 8, 2002 | 11:15 AM
gtcali's Avatar
Default Re: Turbo D16Z6 (VTC_boost-less_CiViC)
So what would you boost on the following:
a6 block
z6 head
blockguard
LS rods
JEpistons .020 over (z6 compression)
Daily?
And for those times when you need a little more boost?
