obd2 to obd2 help
You can't use the teg harness due to its 2 piece design vs the civic's 1 piece design. If you're planning on dropping an automatic B-series in an EK, don't. It pretty much just doesn't work.
-You have to cut and notch the frame rail
-fab up transmission mounts and a rear T bracket
-try to figure out how to control the integra automatic trannty (hint, integra -use a seperate TCU to control the tranny, civics don't
Its far easier, and almost always cheaper to the chassis to a 5 speed.
EG3-R
May 24, 2005 07:45 AM
