A/C not working need help!!!!
can someone please help. its freaking hott. I just recharded the pump. the compressor seems to work. but the air is not cold. any ideas what could it be?
Did you use manifold gauges to ensure that the refrigerant pressure is to spec on both the low and high sides.
When you push the A/C button:
Does the compressor clutch engage? Does the condenser fan run?
