whats the easiest way to change alternator?
If u need tips on how to change a alternator then u prolly arent capable of doing it.Disconnect negative off of batterey,then unplug harness goin to alternator, then take off the 10mm nut that holds the wire goin to it, then there are only 2 bolts on a alternator loosen them swing the alternator back to take belt off then take the bolts completely out and your done
92-95 civic manual says to remove the drivers side axle and take the alt out from underneath but ive been lazy and removed it from above. just takes some wiggleing to get it through
dont_tri
18
Sep 12, 2007 08:58 PM
keithv
Aug 15, 2003 01:11 PM
