d15b8 timing issues.Need help
Old Mar 28, 2009 | 01:03 PM
716pro's Avatar
Default d15b8 timing issues.Need help
So I replaced the head gasket, IT mani gasket and now I and doing the timing on it, the crank is at TDC the cam sprocket is on point and belt is tight. When I run it and put the light on it the timing marks are about 4" off towards the firewall. I have tried it over and over and nothing helps. Moving the dizzy only advances it a little, still off by three inches or so. WTF is going on, any ideas? Obviously the car is running like **** like this, and I dont want to keep running to long like this, anyone know?
Old Mar 28, 2009 | 01:41 PM
Former User's Avatar
Default Re: d15b8 timing issues.Need help
Is the service connector jumped while you are checking the ignition timing? If so, then your mechanical timing is OFF by one tooth on the timing belt.
Old Mar 28, 2009 | 08:59 PM
716pro's Avatar
Yep, had it jumped but still does not make a difference. The cam and crank are where they are supposed to be, no idea wtf is up. Only thing I can think of is a different crank pulley but its unlikely.
Old Mar 29, 2009 | 10:06 PM
716pro's Avatar
Bump
Old Mar 30, 2009 | 05:12 PM
716pro's Avatar
Anyone?
Old Mar 30, 2009 | 05:14 PM
speedooo's Avatar
you need to advance or retard the cam timing before you put tension on the belt...dont remember which...the tensioner pulls the belt to one side
Old Mar 31, 2009 | 10:29 PM
716pro's Avatar
No, I did do that before I tightened it. Its still not wright.
Old Apr 8, 2009 | 07:59 PM
716pro's Avatar
Anyone have an idea?
Old Apr 8, 2009 | 08:26 PM
Post photos showing your cam and crank at TDC1.
Old Apr 12, 2009 | 06:08 PM
716pro's Avatar
Take my word that it is, I have done it 50 times at least on hondas and I know what I am doing.
Old Apr 12, 2009 | 09:08 PM
MonkeyMagic's Avatar
it does, electronically speaking, make a difference
retard cam, or advance the crank... to keep tension on the front side of the belt so the tensioner can pick up the slack
i believe you, but its wrong. mechanical timing must be off. if the bolts are in the distributor it should be damn close. it only gives you like +/- 8 degrees from base 17
tpnorth
Jul 18, 2011 07:30 PM
91efbluehatch
Dec 31, 2010 11:30 PM
Salsa
Feb 28, 2009 11:31 AM
Jap_Spec_Imports
Dec 20, 2007 06:15 PM
JediKGB
Dec 4, 2005 02:29 PM
