NEED WRITE-UP. DA cluster in 91 civic.
Old Mar 28, 2009 | 11:22 AM
95gainfla's Avatar
Default NEED WRITE-UP. DA cluster in 91 civic.
thanks
Old Mar 28, 2009 | 08:00 PM
95gainfla's Avatar
Default Re: NEED WRITE-UP. DA cluster in 91 civic.
ttt
Old Mar 29, 2009 | 12:25 AM
mrrealestate's Avatar
wow.. would love to see this write up materialize.. can anyone help??
Old Mar 29, 2009 | 06:13 AM
95gainfla's Avatar
yeaaa...PLEASE!...if no one helps i might do it, i have done a few write ups before...and its raining so i dont mind sitting in my car with a blunt while i re-wire the cluster. lol
Old Mar 29, 2009 | 12:38 PM
95gainfla's Avatar
so i got most of it figured out already. but none of the diagrams i find explain what wires go to the BLUE clip on the back of the DX cluster(YEL/Yel/Blk), and the GREEN clip on the back of the DA cluster(like a red,red/blk,yellow,something)..
any ideas what these wires are for so i know how to finish wiring this? thanks guys
Old Mar 29, 2009 | 04:32 PM
95gainfla's Avatar
honda-tech is letting me down here.
cluster seems to not be getting power except the high beam and battery lights.
could really use a diagram of the two clusters.
Old Mar 29, 2009 | 04:45 PM
tyler100's Avatar
bump i want to see the same thing i want to do this come on ht
Old Mar 29, 2009 | 05:01 PM
95gainfla's Avatar
i know its going to take a little cutting of the surrounding dash area to get it to fit good, but thats fine with me. id like to be different with the DA gsr cluster
Old Mar 30, 2009 | 05:22 AM
95gainfla's Avatar
commmmmmmmeeeeeeee onnnnnnnnnnnnn.
no one with a da cluster has the pinouts?
Old Mar 30, 2009 | 02:36 PM
95gainfla's Avatar
ttt
Old Mar 30, 2009 | 03:03 PM
ridgeapd's Avatar
http://hondacrx881.tripod.com/gsrclusterswap.html
It's for a DC cluster. Not perfect, but it's a start. I'm looking for it too.
Old Mar 30, 2009 | 03:04 PM
ridgeapd's Avatar
http://www.tamparacing.com/forums/ho...to-ef-pix.html
Getting closer...
Old Mar 30, 2009 | 10:10 PM
95gainfla's Avatar
ah, that last one is almost perfect dude! too bad the first(and important) picture has long been deleted like all the others.
Old Mar 31, 2009 | 08:58 AM
ridgeapd's Avatar
It seems that the DA cluster doesn't fit so well, and that the speedometer may even read incorrectly if installed. From what I've read, its easier to do a DC cluster swap. Just a heads up.
Old Mar 31, 2009 | 09:46 AM
si vtec ftw's Avatar
what possible benefit do you getout of the DA cluster?
IMO it looks lame, even it if fit properly its ugly.
the tach still only goes to 8, and it seems like abunch of work for something that doesnt even work accurately?
go find yourself an ee9 (EDM VT-i) cluster
tach to 9k and its still in MPH
fits right in plugs right up
Old Mar 31, 2009 | 11:45 AM
95gainfla's Avatar
one benefit is the tach, which i dont have now. the difference between my car and everyone elses car could also be considered a benefit by many.
the speedo is only off because its calibrated for the teg tranny and wheel combo obviously. and what happens when im using a teg tranny and wheel size from the car the cluster came from?
Old Mar 31, 2009 | 12:05 PM
sleepingciv's Avatar
91 civic pin outs
Connector A 14 Pins Green
1. Blue/Red -------- Yellow/Red - Seat Belt Warning Light
2. ------
3. ------
4. Pink - SRS Light -------- Black/Yellow - +12V will switch the light off since no DA came with air bags.
5. Blue/White - DRL Indicator - Not Used (Canada Only)
6. Yellow -------- Black/Yellow - Fuse 5 (Canada Only)
7. Green/Red ----------- Green/Blue - Left Turn Signal
8. Green/Yellow --------- Green Yellow - Right Turn Signal
9. Canada: Red/White --------- Red/Blue - High Beam Indicator
USA: Red/Yellow --------- Red/Blue - High Beam Indicator
10. Red/Blue -------- Black - High Beam Indicator (-)
11. Blue/Black ------- Green/Black - Trunk Open Indicator
12. --------
13.---------
14. Yellow/Blue - EPS Indicator - Not Used
Connector B 12 Pins Grey
1. Black/White -------- Green/Red - Door Open Output
2. Red/Yellow -------- Black/Yellow - Fuse 45
3. Red/Black -------- Red/Black - Dash Lights
4. Yellow ------- Black/Yellow - Fuse 5
5. White/Red -------- Black/Yellow - Fuse 25
6. Green ------- Green/Red - Driver’s Door
7. Light Green/Red ------- Green/Red - Passenger Door
8. Black ----- Black - Ground
9. Black ----- Black - Ground
10. Red ----- Black - Dash Lights (-)
11. Green - Wiper Relay - Not Used
12. ---------
Connector C 20 Pins Black
1. White/Black - VSS Output - Not used
2. Red/White -------- Black/Yellow - Ignition Key Switch
3. Blue/White ------- See Speedohealer Wiring
4. ------
5. Blue --------- Blue - Tachometer Output
6. Black/White - Heater Control Panel Illumination Cancel Output - Not used
7. Yellow/Green -------- See ECT Wiring
8. Yellow/Black -------- Yellow/White - Fuel Gauge (you must also tie the Green/Red - Low Fuel Indicator into this wire)
9. -------
10. -------
11. Blue/Orange - Wiper Position Input - Not Used
12. Blue/Black - Intermittent Wiper Request Input - Not Used
13. White/Black - Washer Request Input - Not Used
14. --------
15. Blue/Yellow --------- Red/Black - Cruise Control Indicator
16. --------
17. --------
18. ---------
19. ---------
20. ----------
Connector D 16 Pins Black
1. ---------
2. --------
3. --------
4. ---------
5. ----------
6. ----------
7. ----------
8. Blue/Red -------- Blue/Red - ABS Indicator (or ground if you don’t have ABS)
9. Green/White ------- Green/Red - E-Brake Indicator (pins 9 and 10 tied together)
10. Green/Red ------ Green/Red - Brake System Indicator (pins 9 and 10 tied together)
11. White/Blue ---- White/Blue - Charging System Indicator
12. Black/Yellow ---- Black/Yellow - Fuse 8
13. Yellow/Red ------ Yellow/Red - Engine Oil Pressure Indicator
14. Green/Orange ---- Green/Orange - MIL Indicator (Check Engine Light)
15. Pink - Immobilizer Indicator - Not Used (possible to hook up to an alarm’s LED for *****? Dunno might have to try it).
16. White/Red ------ Black/Yellow - Fuse 25
Old Mar 31, 2009 | 08:21 PM
how is the tach a benefit? my tach in my ef goes to 8 and so does that integra one. i guess if you didnt have an Si then that would be a plus, but wouldnt it be easier to put one in that belongs in that chassis in the first place?
Old Mar 31, 2009 | 08:37 PM
95gainfla's Avatar
Originally Posted by sleepingciv
thanks a ton, but what are those connector listings from?(a-d)
Old Apr 2, 2009 | 05:49 AM
95gainfla's Avatar
burnykawizzle
Apr 27, 2010 07:55 AM
sick stew
Aug 4, 2007 09:29 AM
misha
55
Jan 30, 2007 09:17 PM
chadmasterc
Jun 4, 2005 09:42 PM
XEF-9X
Oct 14, 2002 09:38 PM
