Car bogging and sputtering under light to WOT
I am tuning this guy's car and pretty much hit a brick wall and not sure as to what to do. Its a fully built gsr block with type r head, sc61 turbo with RC 750cc's. I got the car idling perfect and AF is good while revving and raising the rpms up to 4k. Once you are driving and hit light-WOT it immediately leans out to the 17-18's and falls on its face. No matter how much fuel i give it, same thing happens. The timing is set, no CEL's, fuel pressure good, and not sure what else to check for.
i had the same prob. put the gauge on and found the pressure was dropping at max tq . put a fpr on and set it to 80psi and no problem.
Plugs look good, aem wideband, s300. I changed out the FPR to a stock one and the fuel pressure went up from 48 to 52psi and it richened out a little but still not getting enough fuel. The owner of the car just told me that the ECT sensor is bad which might explain why it does this when the car gets fully warmed up. We'll see later today.
1SlowSi
Engine Management and Tuning
10
Apr 6, 2009 05:28 PM
suzuki515
11
Aug 3, 2005 03:59 AM
