Car bogging and sputtering under light to WOT
Old Mar 28, 2009 | 10:03 AM
1SlowSi's Avatar
Default Car bogging and sputtering under light to WOT
I am tuning this guy's car and pretty much hit a brick wall and not sure as to what to do. Its a fully built gsr block with type r head, sc61 turbo with RC 750cc's. I got the car idling perfect and AF is good while revving and raising the rpms up to 4k. Once you are driving and hit light-WOT it immediately leans out to the 17-18's and falls on its face. No matter how much fuel i give it, same thing happens. The timing is set, no CEL's, fuel pressure good, and not sure what else to check for.
Old Mar 28, 2009 | 12:33 PM
Lewy. Dee Ayy's Avatar
Default Re: Car bogging and sputtering under light to WOT
hes got at least a walbro 255 right?
Old Mar 28, 2009 | 01:23 PM
1SlowSi's Avatar
Yeah, but see, this issue is happening with 20-100% throttle. Tip in adjustments dont make a difference either.
Old Mar 28, 2009 | 04:40 PM
98lude-t's Avatar
is fuel pressure good while driving. or good just sitting there and reving.
Old Mar 28, 2009 | 04:42 PM
98lude-t's Avatar
i had the same prob. put the gauge on and found the pressure was dropping at max tq . put a fpr on and set it to 80psi and no problem.
Old Mar 28, 2009 | 04:57 PM
Redcoupe's Avatar
AEM Wideband?
Hondata S300?
Plugs look like what?
Old Mar 29, 2009 | 05:54 AM
1SlowSi's Avatar
Plugs look good, aem wideband, s300. I changed out the FPR to a stock one and the fuel pressure went up from 48 to 52psi and it richened out a little but still not getting enough fuel. The owner of the car just told me that the ECT sensor is bad which might explain why it does this when the car gets fully warmed up. We'll see later today.
Old Mar 29, 2009 | 08:20 AM
Mag00n's Avatar
check timing too
Old Mar 29, 2009 | 01:03 PM
Silva Bullit DC4's Avatar
Make sure you post this in the Engine Management & Tuning section as well, homie.
Old Mar 29, 2009 | 05:38 PM
1SlowSi's Avatar
ECT sensor fix did nothing
Old Mar 29, 2009 | 07:08 PM
Redcoupe's Avatar
Interesting.
Car isn't a black ITR is it.
Old Mar 30, 2009 | 03:22 PM
1SlowSi's Avatar
Originally Posted by Redcoupe
Interesting.
Nah man, what makes you say that? haha I told Doug about it and he said he's gonna talk to Shawn. I dont know where he's gonna find a fuel pump to use so good luck with that.
Silvertc
Sep 23, 2010 09:49 AM
1SlowSi
Engine Management and Tuning
10
Apr 6, 2009 05:28 PM
suzuki515
11
Aug 3, 2005 03:59 AM
lilcasino
May 17, 2002 03:13 PM
