b20 swap question.
Old Mar 27, 2009 | 05:10 PM
lrayford's Avatar
Icon2 b20 swap question.
what has to be done to make a b20 obd2 run in a obd1 integra, sorry im a obd1 prelude guy :/ i dont know anything about b series
Old Mar 27, 2009 | 06:04 PM
92b20teg's Avatar
Default Re: b20 swap question.
jus an obd 1 LS dizzy, plug all the unimportant vacuum lines and say fudge it
Old Mar 27, 2009 | 06:13 PM
lrayford's Avatar
so your telling me.... all it takes is to use a obd1 ls dizzy and bolt it in. and cap off some vac lines.... word... and no check engine light or nothing?
Old Mar 31, 2009 | 05:43 PM
lrayford's Avatar
bump?
Old Mar 31, 2009 | 07:07 PM
vinceg143's Avatar
wtf does bump mean
Old Mar 31, 2009 | 07:10 PM
thabao's Avatar
Bump
Old Mar 31, 2009 | 07:41 PM
CompanyFlow's Avatar
You're going to get a CEL. I think you need an obd1 ecu as well.
Old Apr 1, 2009 | 12:34 AM
V8 Eater's Avatar
what you need to do is put everything that is on the ls motor that is in your integra onto the b20 such as tb,intake manifold,exhaust manifold,dizzy,starter,alternator and plug all the plugs and lines that were on the ls exactly the same way onto the b20!
do not worry about the sensors that come in extra with the b20 as you will be using your stock obd1 ls ecu which wont give out codes since it never did read those sensors(such as knock sensor). basically assume that you took your ls out and your putting it back in cause an b20 is an ls actually. do not forget the most important one is that you use the ls dizzy, just install it the same way it is on your ls
Old Apr 3, 2009 | 08:19 AM
^ What he said. I had it backwards.
Floyd Roger
Oct 19, 2016 05:36 PM
psudo-si
Texas -OK -LA (Sales)
May 16, 2012 07:05 PM
alex22
Aug 12, 2011 12:49 PM
haroldthefly91crx
Apr 21, 2008 04:50 PM
BLUE EH3
Oct 3, 2004 08:32 AM
