Finally its done. Need critiques on my S2000 engine removal and install guide...
I've written an article on how to remove and install the F20C engine. Check it out and let me know if it needs any corrections.
Honda S2000 F20C Engine Removal. Garage411.com
Honda S2000 F20C Engine Installation. Garage411.com.
The complete list (updated 5/4/2009):
S2000 Brake System
S2000 Cabin AirFilter
S2000 Cam Chain
S2000 F20C camshafts.
S2000 F20C camshaft gear removal and installation.
S2000 Clutch
S2000 Interior Console
S2000 Cooling System
S2000 F20C Crank Pulley
S2000 F20C crankshaft.
S2000 F20C Cylinder Head
S2000 F20C cylinder head inspection.
S2000 F20c Engine Install
S2000 F20c Engine Removal
S2000 interior dash removal. Garage411.com
S2000 Exhaust System
S2000 F20C flywheel removal and installation.
S2000 Horn
S2000 Hub Assembly
S2000 Ignition
S2000 Immobilizer
S2000 Lubrication system
S2000 Interior Seats
S2000 rocker arms. Garage411.com
S2000 Rear Suspension
S2000 Trunk
S2000 Universal Joints
S2000 F20C Valve Clearance
S2000 VTEC solenoid test
S2000 Wheel Alignment
S2000 Wheel Bearing
S2000 Brake System
S2000 Cam Chain
S2000 Clutch
S2000 Horn
S2000 Hub Assembly
S2000 Ignition
S2000 Immobilizer
S2000 Trunk
S2000 Wheel Bearing
yes isnt that pic from the guy who did the FWD F20c swap in spain . if its not the same pic he had its almost exactly the same pic in his build thread , or i might of seen it in inline pro's fwd thread cant remember which one
Thanks. Its definitely a lot of work to put this all together. Let me know if you guys have any other suggestions on what to put on the list.
SiR HatchAlot
22
Jul 29, 2003 02:34 PM
turbopyitr
Oct 22, 2001 01:36 PM
