Crank Pulley Bolt
i used one of those and was the greatest tool ever for this. I got one locally as i didnt have access to an impact
The $30 ebay tool (two metal rods welded onto a big nut) works great.
Use the tool, a breaker bar, and some extensions. Rest the extensions of the breaker bar on a jackstand and then put the breaker bar at a ~45-60º, pointing towards the front of the car, and give it a big heave. Use the tool to hold the crank pulley still and the bar on the tool will rest against the front control arms
Buddy of mine has a 3/4 impact, thinking of giving it a shot. A little scared it might twist it off though. Another thing, can't I put a timing belt on without taking the pulley off?
Don't do that... if you do that then you won't be able to put it back on. And without a timing belt cover, your timing belt is exposed to more dirt, etc. and won't last as long. It's really not good for it.
Why don't you try using the tool to get it off? I've changed two timing belts and each time, the impact wasn't enough to budge it. I used the tool, a breaker bar, extensions, a jackstand, and a pipe and gave it a quick blow and it came loose, both times.
Don't take shortcuts, just use the tool and a breaker bar.
i just took mine off today actually, just used a breaker bar and a deep socket, jack up the car way high so you have room to swing the bar underneath, and get someone to go inside the car, put it in gear and step on the brakes real hard. then, position the breaker bar so that you can grab onto the front of the car and push on the breaker bar with your foot. your legs are much stronger than your arms =D
Okay fellows, I've been in the shop working tonight and worn SLAP as out from fooling with this thing. I'm gonna hit it again Saturday and see what happens. This is not like the first time I've done timing belts. I've done numerous ones and have NEVER had one that's a pain in the *** like this. Most of the time if I can't get it to break with an impact wrench, I throw a little heat to it and it breaks right aloose, not this time. Gonna try again tomorrow and do what Red suggested. I did pull the belt out as it was broke anyways, 140k on it I'd bet anything!
I have a hex tool for you to use, I just bought it and it doesn't fit on my car, but it does fit on yours. Where are you located? Your profile says WV? I'm in morgantown
Thanx, but I'm actually in Ms. Nice of you to offer. Gonna borrow my buddy's 3/4 impact and it this will break it loose, or off in the crank.. Lol, Prolly be my luck.
leave the car in 5th gear...heat up the bolt and throw water on it right after so it shrinks, then blow it off with the gun. worked on my s2000 and I tried everything and I also had the tool to hold it.
ya because heat expands it and cold shrinks it...give it another shot with water. Mine came off too easy with the impact after that. I'm telling you before the heat and water we tried everything lol
I have a huge 80 gallon 2 stage compressor, but obiviously a POS impact wrench although it has worked in the past. Hey, Honda's are "put together".
Like to thank all you fellow
