looking into engine work...
Old Mar 27, 2009 | 10:55 AM
Canadian_EF's Avatar
Default looking into engine work...
I have been looking at engines for a while. I was thinking of a ZC, but I heard that it is not worth the money. The B16 is too much money for me...
If I was to overhaul my CRX Si engine, any recommendation on parts to swap? Camshaft, pistons... from where and how much are they?
All I want is a zippy DD for the summer. One that won't fail when someone tries to race me.
Old Mar 27, 2009 | 11:18 AM
shaggyeg6si's Avatar
Default Re: looking into engine work...
I'd get aftermarket pistons just to bump the compression a little and invest in a port and polishing kit. Decent parts and small jump in power for very little in price. Cams will help, but you have to make sure you clearance the motor to make sure you don't tap the pistons with the valves.
Old Mar 27, 2009 | 11:35 AM
Dark_Teg's Avatar
JRSC is what I would do to a "healthy" stock CRX Si on a budget. They can be had pretty cheap used. The money spent would be about the same in the end but with much better results.
Old Mar 27, 2009 | 02:27 PM
CRX Toad's Avatar
This thread is pointless do some research then pick your motor.
Also street racing is for idiots.
W90crzsi
37
Jul 28, 2023 06:08 AM
katanamast279
Jun 8, 2009 10:57 AM
rangerxtrn
Mar 24, 2008 10:57 AM
superex87
Apr 8, 2007 02:35 PM
1stcrxman
10
Jan 25, 2005 06:31 PM
