battery light with a mind of its own
Old Mar 27, 2009 | 10:54 AM
rattlecannedEF's Avatar
Default battery light with a mind of its own
my battery light flashes at random. sometimes right when i start the car, other times it stays off. it mostly happens when the rpm hits 5 or 6k.
the radio can be on as loud as i please and its fine. and my voltmeter doesnt drop. the battery is brand new so are all the connections and grounds in the engine bay.
whats causing this?
Old Mar 27, 2009 | 01:26 PM
digitally_remastered's Avatar
Default Re: battery light with a mind of its own
i would like to know as well. i was told though that it may be that the regulator inside of the alternator may be on its way out. mine is doing the exact same thing, but i dont have any voltage drops. light comes on and off as it pleases.
Old Mar 27, 2009 | 02:33 PM
CRX Toad's Avatar
Alt going out.
Old Mar 27, 2009 | 06:25 PM
thanks.
its always the exspensive stuff
Old Mar 27, 2009 | 08:12 PM
Originally Posted by rattlecannedEF
thanks.
hey man, it could always get worse. just thankfully its not. other people got it worse than a simple alt change. and 95 bucks isnt bad at all for an alt.
Old Mar 28, 2009 | 06:39 AM
honda.lioness's Avatar
The battery icon on that light is misleading. It is actually the charging system warning light. Toad's right to check the alternator but check also all charging system wiring and the alternator belt. It could be just a loose connection, even a corroded nut, or simply a loose belt. If it is the alternator, there is a good chance you can just replace the brushes (for $10-$30 for parts). See http://honda.lioness.googlepages.com...alternatortips and http://honda.lioness.googlepages.com/alternatorbrushes .
If the alternator has more than 100k miles on it, then the brushes are a strong candidate here. The alternator bearing is also known to fail on older alternators.
Old Mar 30, 2009 | 08:41 AM
i looked at the alt the other day and i noticed the belt was starting to tear. could i get away with just changing the belt?
Old Mar 30, 2009 | 11:59 AM
Why risk a failure while driving? Change it and eliminate it as a possible cause here. Make sure you get the belt tension right. Not too tight, else it is hard on the alternator. Not too loose, else the charging system will not get the juice it needs. The belt may indeed be the problem.
Old Mar 30, 2009 | 12:10 PM
CW-ITR's Avatar
Here ya go, $10.99 on ebay. I fixed my '88 CRX alternator with this part:
http://cgi.ebay.com/HONDA-CIVIC-ALTE...3286.m20.l1116
Old Mar 30, 2009 | 09:22 PM
thanks guys, ill give it a go when i get paid.
Old Apr 2, 2009 | 12:07 AM
88_acED6's Avatar
ok my car has a brand new battery, alternator, belt and new and added grounds through out the bay and battery light comes on at around 6-7k but just flashes really fast....wtf
Old Apr 2, 2009 | 12:23 AM
ArtyG's Avatar
Belt slipping?
My friend's EK was doing the same alternator thing. Ended up replacing the alternator, adjusted the tension on the belt, and was good to go.
Old Apr 2, 2009 | 06:53 AM
MonkeyMagic's Avatar
Originally Posted by CRX Toad
Alt going out.
maybe
the light is coming on when that charging circuit opens. could be a brush in the alternator "jumping" or a bad connecting in the alt line, etc.
i had a b16 once that i could damn near use the battery light as a shift light. battery never died, alt held it together. lol
M3THTICAL(EF)
May 4, 2015 06:05 PM
aalb1
Aug 5, 2013 09:47 AM
bleedblue94
May 20, 2006 07:57 PM
