Pics of my new B16 swaped VX
Finally got the pics hosted!
The engine bay is cleaner now and I finally wired in the 4-wire o2 and fixed a problem with the TPS (I had it installed offset
). No Check Engine Light now!!! Smoking before was a combo of high idle and no o2 giving me tons of fuel. Engine runs clean and hasn't used any oil
Here is some pics about 2 hours after the swap was done, sorry for the poor quality but you get the picture
"is swapping in a b16 in a vx any harder/different with other models? (cuz i got a vx) what was up with your O2 problem?"
the problem with the 02 is that it is only one wire....(correct me here) i had that problem with my cx harness, you need 4 wire.....
BTW clean valve cover.... i need to get my spare cover dipped too...
looks good, but I would put that cover back on where the a/c shoul dbe at since I noticed you have a ceramic coated header...cuz if you get rocks hitting it, the ceramic coating will chip and not look good...but the swap looks sweet!
