Aftermarket Gauges
I was going a 3 pod set of glowshift gauges.
More then likely the vacuum, then the air/fuel, and the last one the volts gauge.
Has anybody here bought any aftermarket gauges.
How hard was the installation, and where do wire this stuff up to?
Thanks
Thanks
From: Where We Squeeze 1st N Ask Questions Last, CA, USA
It's not hard at all if you're a DIYer.
Vacuum you install on your vaccum line, which is the hose coming from your brake booster. But really, what's the point. "cool factor?"
Air/fuel, you install on your 02 sensor, but why? Is it wideband?
Volt gauge, on the battery if possible. I guess if you're running a lot of electronics.
gsr98vtec
Feb 1, 2002 09:05 AM
