suspension question
hey, guys! i have a 2000 honda civic si and i wanna the do the suspension on it but i wanna do it really good but with spending around $2000... so far i picked out these parts and im thinking i made pretty good choices but i wanna know what the rest of you guys think???
i need as much info as i can get before i order all these parts so give me as many helpful hints as you can please!!! thank you!
ASR Rear Subframe Brace
Skunk2 Pro-S Full Coilover Kit
ASR Spherical Rear Sway Bar End Links
Skunk2 Rear Lower Control Arms
Skunk2 Rear Tower Bar
Skunk2 Front Tower Bar
ASR 24mm Swaybar & Bushing Kit
Skunk2 Pro Series Plus Front Camber Kit
Skunk2 Pro Series Rear Camber Kit
i need as much info as i can get before i order all these parts so give me as many helpful hints as you can please!!! thank you!ASR Rear Subframe Brace
Looks fine to me, but look at the Integra Type R rear sway bar (23 or 24mm I think). I got my used one for like $110 or something. It was cheaper than aftermarket at least, and I just shot a coat of paint on and it looks brand new.
Read up on camber. Some neg camber is good for handling, too much is bad for tire wear and ball joints. Ball joint replacement sucks big time.
i have a camber kit on my car already and coils but i wanna get all new **** cause mine is already all ****ed up so i do need a camber kit for sure cause the height that i want the car makes my car camber really bad and thanks for the tip... ill look into the itr sway bar and see if i could find one!
etank82
Honda Civic (2006 - 2015)
Aug 28, 2010 08:32 AM
