Fitting ITB's issues with vacuum
hi,
im fitting a set of ITB's to my B-series.and im having a bit of trouble with how to set up my vacuum stuff like my idle control motor. the map sensor and all the other sensors that are there...
any help or pictures appreciated
The idle air control valve (IACV) you can leave attached to the firewall, or loop the water lines and remove it completely. It is a non-functioning item with ITB's. The resulting CEL can be dissabled in most rom editing softwares like CROME, Hondata...etc
Run one vacuum line from each runner to a separate vacuum manifold. You can use the Golden Eagle unit HERE, or make your own using a 2" x 6" PVC tube and drill and tap your own fittings. From this manifold, you will run your brake booster line, MAP sensor, and any other vacuum based mechanism you have (FPR, etc).
You can mount the intake air temp sensor (IAT) anywhere. Since you are injesting air from the engine bay, your air temperature based fuel corrections will be basically spot on if the IAT is located near the throttles.
he's right but the only problem i ran into with using the golden eagle manifold is that there was not enough reserve vacuum for sudden throttle blips. so i built one out of some 3 inch aluminium intake piping and welded caps and the end like you would do if you used pvc pipe. i also have my iat sensor hanging by the end of the velocity stacks on the throtle bodies and it seemd the work fine
thanx ppls thats got her sought i think as i already have the golden eagle vacuum tank just didn no wot to do with the IACV and the IAT but should be able to sought it now thanx
roll8221
Engine Management and Tuning
Apr 1, 2015 11:29 AM
tempsohc
Jun 19, 2011 06:06 PM
K i l l a B e e.
Nov 24, 2008 05:41 AM
