idle problem
Old Mar 26, 2009 | 06:54 PM
b18b1ef8's Avatar
Default idle problem
i have a 90 crx hf with a full obd0 ls swap and when i start it in the morning it jumps in idle from 2-3thousand rpms only untill it gets hot ,then it idles fine at around 800
ive tried replacing the iac valve with others ive had laying around in my garage but all does the same problem. any ideas of what it could be ? thanks
Old Mar 26, 2009 | 08:42 PM
b18b1ef8's Avatar
Default Re: idle problem
bump please helpp
Old Mar 26, 2009 | 08:48 PM
Donkey85's Avatar
um dude its saposed to do that, thats what warms the car up quicker then drops the idle down when its warm
Old Mar 27, 2009 | 06:29 AM
b18b1ef8's Avatar
nahhhh u dont understand ,the idle goes back and forth from 2000 to 3000 back and forth untill it gets hot, its not a vacume leak and i replaced the iacv 3 times with other used ones so i dont think all 3 were alll badd
Old Mar 27, 2009 | 06:45 AM
aaronhume's Avatar
vacuum leaks would usually make it bog down really bad when you tap the gas. however you might want to try cleaning out (or replacing) the iacv (on the back side of the intake manifold) that controls cold idle. this is a relatively common problem on those engines.
Old Mar 27, 2009 | 07:02 AM
ef-hatchcrap's Avatar
Have you checked the fitv underneath the throttle body?
PROJECT 91
Sep 25, 2009 11:18 AM
DC2andED6
May 9, 2009 02:55 PM
supradrifter
Dec 19, 2006 08:43 AM
b16crx88
Mar 19, 2005 11:14 AM
TheIntegraGuy
Jan 22, 2004 06:48 PM
