VTEC not engaging, need help trouble shooting! Thanks!
Old Mar 26, 2009 | 04:12 PM
christian7750's Avatar
Default VTEC not engaging, need help trouble shooting! Thanks!
I just got my head rebuilt and new pistons and got a S100 hondata. I took her up past 6000rpms and vtec didn't hit. What are some things I need to check?
Old Mar 26, 2009 | 04:15 PM
hookedonponics's Avatar
Default Re: VTEC not engaging, need help trouble shooting! Thanks!
check your oil level.
Old Mar 26, 2009 | 04:16 PM
Brand new oil bud
boostedcivicsir's Avatar
Mr. Badwrench
did you have the hondata before? (meaning did you have vtec before on a stock ecu)
Old Mar 26, 2009 | 04:17 PM
I had vtec on stock ecu, but did a rebuild and put the s100 in and no vtec
Old Mar 26, 2009 | 04:19 PM
RowenSpec-V's Avatar
Have you verified connectivity to your solenoid?
Old Mar 26, 2009 | 04:20 PM
Yes
Old Mar 26, 2009 | 04:44 PM
MonkeyMagic's Avatar
no cel?
what ecu is running the hondata. is vtec enabled on the computer end?
Old Mar 26, 2009 | 04:50 PM
P28. There is a cel but its code 9 which is the distributor, but i was using the same distributor on my old set up with the same cel. And vtec should be enabled, I took it to this guy who put a base map on there, i don't see why he wouldn't enable it. He told me to take my car to vtec to make sure it was working.
Old Mar 26, 2009 | 05:26 PM
bump
Old Mar 27, 2009 | 02:08 PM
Mr. Badwrench
if thats what was changed, you need to start there. see if it isn even enabled, or if it has a higher crossover point.
Old Mar 27, 2009 | 02:25 PM
93egSLEEPER's Avatar
what distributor are you running? a distributor CEL probably isnt something i would want on just for kicks... i would solve that as well
Old Mar 27, 2009 | 02:29 PM
fireblaze2k1's Avatar
See if you can get a P28, and see if you have problems. Double check the stock ECU to see if it throws codes, if it runs fine, then I would think something was not done right with the S100
Old Mar 27, 2009 | 02:30 PM
veightkiller's Avatar
+1
XxfatlacexX808
Mar 12, 2013 07:18 AM
DC2tuner86
Jul 22, 2010 05:25 PM
MOST
11
Feb 28, 2007 01:29 AM
h22silvia
Oct 12, 2006 08:24 AM
Forrest Gump 9
Aug 11, 2003 05:26 PM
