my battery keeps dying
basic diagnosis of a battery that keeps dying is checking for a parasitic draw on the battery. you do this by getting an ammeter or multimeter(in amp mode) and hooking it up in series with the negative battery terminal... CAUTION: check the amperage rating on your meter and make sure it has a decent amp rating. my blue point meter has a 10amp fuse.. i have never blown mine.
dissconnect the neg terminal,
connect the neg lead on the meter to the battery termnial
the pos lead of the meter to the cable.
if you have a draw you will get an amp reading.
if you do, start pulling fuses until the draw goes away, once the meter reads close to zero you know what circut is creating the draw. once you know what circut it is, get a helms manual or look for diagrams online to that circut and find out where the voltage is going.
usually a resistance or a short to ground before a switch in the circut.
hope this helps
btw before going thru all of this check your interior lights and make sure you are not leaving anything on.
-kidfrost
hope this helps
-kidfrost
thanks for the help you guys....anything else? im gonna keep trying everything yall shoot at me ive invested to much money into this car...what relay relays do yall think it might be? thanks
teryx000
13
Aug 25, 2009 06:48 AM
dianam321
Oct 28, 2008 05:24 AM
