idle surging after load
Old Mar 26, 2009 | 12:34 PM
92civtegra's Avatar
Default idle surging after load
i just put my H22A into a 1994 accord EX-R
i used the F22B1 harness blah blah
it was running fine but i started driving it yesterday and now it runs fine under load but as soon as it comes back down to idle it surges about a thousand RPM for a minute then the idle cleans back up and runs normal
Old Mar 26, 2009 | 12:41 PM
JDubya's Avatar
Default Re: idle surging after load
Which ECU are you using? I had a bad idle surge problem after my turbo install but it was because I was using a chipped civic ECU, which I was told would work fine. Once I switched to an LS ECU it was fine.
Is your idle like this?
http://www.youtube.com/watch?v=dxeJsxgTMmA
edit: i reread your post and it sounds like yours is just one long surge, never mind.
Old Mar 26, 2009 | 04:22 PM
locosiete's Avatar
getting any trouble codes?
Old Mar 30, 2009 | 11:37 AM
92civtegra's Avatar
ok update with that.....
on the driver side kind of beside the motor mount there is a valve with 2 vac lines going into it and an electrical plug
when it is unplugged it runs smooth but after load the idle still surges about a thousand RPM
but when its plugged in it doesnt surge but runs rough and sounds like severe misfire
ideas?
Old Mar 31, 2009 | 06:27 AM
locosiete's Avatar
a pic might help
RinzEG6
Nov 24, 2014 12:02 PM
Turbo_y8
May 5, 2006 10:30 PM
freddy_hung
Acura TL, RL & ZDX
Nov 25, 2005 03:07 PM
LSpimpTEC
Apr 28, 2003 11:29 PM
