my distributor only gives spark to 2 plugs
Old Mar 26, 2009 | 11:54 AM
HondaKid936's Avatar
Default my distributor only gives spark to 2 plugs
i am having trouble starting my ls vtec my distributor was working perfectly fine one week ago and my friend tried to troubleshoot with his motor using my dizzy and it did the same thing his old dizzy was doing no spark only on 2 plugs.... i put it on my car and i have that problem now what could be the reason
Old Mar 26, 2009 | 02:38 PM
Default Re: my distributor only gives spark to 2 plugs
bump
Old Mar 27, 2009 | 08:46 AM
okay i tried my friends b18 dizzy and it does the same..... this is a working dizzy i think i have a problem with my harness?
<h1>please help honda tech!
Old Mar 27, 2009 | 08:48 AM
hondachris1994's Avatar
Try a different ecu. Did someone hack the wires goin to the dizzy?
Old Mar 27, 2009 | 09:19 AM
i have a boost map loaded on my p28... someone said i have to reset my ecu?
i had taken off my dizzy to fix a cam seal thats basicly it and it started acting up like this.
Old Mar 27, 2009 | 10:21 AM
Former User's Avatar
Are the plugs or plug wires possibly bad for the two non-firing cylinders?
Old Mar 28, 2009 | 11:08 AM
the plugs are good and i have 2 sets of wires.... anyone have this problem before?
Old Mar 28, 2009 | 11:11 AM
civic_driver's Avatar
Are you sure you have hooked up the wires in the correct order to the dizzy?
RanCRX
May 19, 2011 01:00 PM
OneFire
Jul 3, 2010 03:09 PM
mynameizstitch
Jun 8, 2009 07:29 AM
97civic07gsxr
10
Apr 6, 2009 07:16 AM
willsEK-HF
Feb 26, 2006 12:53 AM
