o2 sensor problem
Old Mar 26, 2009 | 11:09 AM
zenon8890's Avatar
Default o2 sensor problem
my car does a 180miles per full tank, i've changed everything u should think of to make it better, nothing worked, how do i know that my o2 sensors are fully functional?! i dont have any CEL
Old Mar 26, 2009 | 11:10 AM
Pothole987's Avatar
Default Re: o2 sensor problem
How about your thermostat? The temperature at which your car is running ( like too cold) will DECREASE your mileage.
BTW if there are no CELS then usually the o2 is good.
Old Mar 26, 2009 | 11:17 AM
zenon8890's Avatar
its always average, but my car drinks my radiator fluid weekly a little, i dont see any leaks and i've changed my thermostat switch twice cuz it stopped working suddnly
Old Mar 26, 2009 | 11:39 AM
thumper64's Avatar
A lazy O2 won't throw a code. It's only when they get really bad that they will throw one. I say find one, switch it out and either it will work or you got one for when you do need it.
Old Mar 26, 2009 | 01:10 PM
silver-ek4's Avatar
if its drinkin radiator fluid but u dont see any leaks u may have a blown head gasket
Old Mar 28, 2009 | 05:36 AM
zenon8890's Avatar
but my car doesnt overheat
zenon8890's Avatar
and it doesnt have to do anything with my problem
Old Mar 28, 2009 | 06:41 AM
sde780's Avatar
Don't buy a cheap one, it's best to go OEM. I bought a Bosch O2 sensor and half a year later it's failing on me.
Check your tires, brakes for dragging, tune-up stuff?
Old Mar 28, 2009 | 09:03 AM
zenon8890's Avatar
i have oem o2 sensor, i have new brake pads and rotors too
Old Mar 30, 2009 | 01:57 PM
zenon8890's Avatar
so whats the problem?! i used a scanner for my car to check if my car is like factory civics, everything looks fine. i drive like a granny and i use 90 octane unleaded fuel. my auto tranny seems to slip on 2nd but it doesnt make that such thing
Old Mar 30, 2009 | 02:04 PM
zenon8890's Avatar
how do i know if my injectors are not just pouring fuel into the engine? i dont have smoke at all, its like my engine blows air from the exhaust, no colors or smoke at all
milkwasabadidea
Oct 30, 2011 07:23 PM
Nooget
13
Aug 14, 2010 08:12 PM
CivicRider011
Dec 17, 2006 10:16 AM
mxl36o
Aug 4, 2006 06:09 PM
Joel_MN
Apr 1, 2004 11:15 PM
