GT3582r OR SC6162SPR...?
Old Mar 26, 2009 | 09:01 AM
vadimkag's Avatar
Default GT3582r OR SC6162SPR...?
Which one is better gt35 or sc6162..? They cost the same and I dont know wich one is better for my LS Vtec.
Old Mar 26, 2009 | 09:03 AM
locash's Avatar
Default Re: GT3582r OR SC6162SPR...?
Buy the garrett.
Old Mar 26, 2009 | 09:05 AM
IceySC's Avatar
i would like to know as well plus if 81.5mm is a to small for them.
Old Mar 26, 2009 | 09:19 AM
1qucksol's Avatar
^ full boost hits way to late, like 6k talk about lag i was running a 81.5 b16 with crower FI cams, went with an erl SD2 84mm stroker motor to hopefully take care of the lag on the 35r,
Old Mar 26, 2009 | 09:22 AM
boostedeg6-1's Avatar
Full boost does not hit late on the 6162 on an 81.5mm, i had one on my stock sleeve set up full boost around 5400! Both are great turbo's 35r might make a lil bit more power maxed out
vadimkag's Avatar
With .82 and ball bearings full spull should be at 4,500rpm... ?
Old Mar 26, 2009 | 09:29 AM
You go to speedfactory right??? Probably right after 5k if its a b16. ball bearing isnt too much spool time, its the transient response in between gears and how much boost it holds. You will be happy with either turbo..
Old Mar 26, 2009 | 09:35 AM
red02s2k's Avatar
I have the sc6162 it's great I hit 18psi at 4600rpm
Old Mar 26, 2009 | 09:40 AM
vadimkag's Avatar
It's 81.5 Ls Vtec so I think should be better than that, pluss I'm using Blox B's cams.
So gt35 or 6162.???
SpeedFactory yes...
Old Mar 26, 2009 | 12:03 PM
TheShodan's Avatar
Moderator
They are saying the Both work.. there's not much of a "X is better than Y" because they're both good.
Old Mar 26, 2009 | 07:57 PM
vadimkag's Avatar
I know they are the same that's why I'm asking wich one would you buy garrett of precision..?
Old Mar 26, 2009 | 08:15 PM
TheShodan's Avatar
Moderator
Not sure. depends upon my budget, and what car I was using. I'm sorry if I seem vague. it's just hard to have an opinion of comparison, because I'm not you..
Old Mar 26, 2009 | 08:33 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
lol....perfect thread for me right now...
Old Mar 26, 2009 | 10:42 PM
vadimkag's Avatar
Looking for one too..?
Old Mar 26, 2009 | 11:02 PM
jdm602's Avatar
i thought the sc6162 was rated higher. 680 with the 76 ptrim. 3582r is rated for 600. and if you look around, the sc6162 is a little cheaper too.
Old Mar 27, 2009 | 06:39 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
well i have a t3/67 and i need something smaller.
Old Mar 27, 2009 | 06:57 AM
ScorpionT's Avatar
Both are good, but price wise the Precision stuff is generally more appealing.
Old Mar 27, 2009 | 07:27 AM
pOrKcHoP bOy's Avatar
Dyno and In-dash video of my DBB Precision T61, .68 A/R hotside (smallest available). The in-dash shot at the end shows full-boost was reached @ 4000-4200rpms, I hope this helps. If you listen to the engine on the dyno, the power curve is quite extensive and very broad. Car revs to only 7,200rpms before fuel cuts
http://www.youtube.com/watch?v=w52IjgtvAgo
Sorry its not a Honda, but I have not seen too many T61 videos on youtube, so I hope this helps you narrow down the decision
Old Mar 27, 2009 | 08:38 AM
E85B18's Avatar
Id go with the 3582 but lag is going to be bad on both. What are your power goals, is this for a street car? I had a 3082 on my 81.5 and even that had more lag than id like.
Old Mar 27, 2009 | 08:44 AM
vadimkag's Avatar
It's a street car so 500whp
TheShodan's Avatar
Moderator
Define "smaller". In dimensions, power goal, or use?
Old Mar 27, 2009 | 10:30 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
well i bought it when i was going to do a built. motor. then i sold all the internals and just finished the set up on a stock GSR. I make 415 on my stock GSR but im about to retune to 450-470. when i add my R cams and rev it to 9k.
So I want a good turbo that will make the power with room to spare on top incase i do decide to build another motor.
I never plan to really make over what a stock fuel system can handle...(walbro stock FPR 1000 ID injectors E85 or race.
So there are my limits. that's why Im leaning towards the GT35R.
Old Mar 27, 2009 | 11:17 AM
TheShodan's Avatar
Moderator
Honestly, you might as well keep the T67 at that rate, since you may grow again later, and at the higher levels, the "spool" characteristics are moot by that point. Plan 2 steps ahead, not just the one. 470whp on a stock block, I don't care what fuel you use, is a ticking time bomb in the long run. But, if that's what like...do you.
Old Mar 27, 2009 | 12:02 PM
vadimkag's Avatar
So 6162 better..?
Old Mar 27, 2009 | 01:26 PM
TheShodan's Avatar
Moderator
Originally Posted by vadimkag
So 6162 better..?
No. you're still probably not going to any solid answers to this. It's not a BETTER issue. It really isn't. It's not that cut & dry. Sorry.
