havin trouble gettin the shift knob off
so i found a thread that says to turn it counter clockwise and eventually it will come off, well how long did it take for it to come off? i prob sat there for 15 min turning it and it still would not come off, any suggestions?
they said it could take up to 5 days of turning ;-)
ahh sorry, umm it shouldn't take that long. and really if you are unscrewing the shift **** you should notice it moving upwards... and the threads should start becoming noticeable. if so then you are on the right track. if you turned for 15 min and still don't see the threads thennn i would check to see if there is something else holding that **** on (sometime after market ***** have little screws that tighten down to hold the **** in place)
yeah pics of **** i had one that did that turned out had to unscrew the top and slide it down to remove the little nuts (i thank you (A. powers)) and wala
It's probably a set screw shift ****. The aftermarket ones usually have three little screws that tighten down onto the shifter, not the actual threads. Is there a section on the bottom of the shift **** that unscrews to reveal the heads of the screws?
I3ackfire
Feb 23, 2004 05:23 PM
